Security [CENTRAL] Forum - SCforum.info
23. May 2012., 09:29:18 *
Welcome, Guest. Please login or register.
Login with username, password and session length
SCforum.info - Security [CENTRAL] Forum
↑ Grab this Headline Animator
Custom Search
News: For ultra cheap bullet proof vests, hard armor ballistic plates or for advice on body armor in general visit SafeGuardClothing.com
  Home Help Chess Links Login Register   *
SCforum.info
furniture store
Total Members: 11253
Latest: pluskit011
Total Topics: 4334
Online Today: 2742
Online Ever: 51419
(01. January 2010., 10:27:49)
SCF UnSpam
Top Ten Antivirus Software
Friend of WOT
SCF Feedburner
SCF Facebook
SCF Twitter
Welcome to SCforum.info - Security [CENTRAL] Forum, a home of the SCF Community devoted to provide Computer related News, Alerts, Downloads and FREE Help in such a way that even the novice computer user can understand.
Getting started using our community is extremely easy, check the two steps below:
Step 1: Create an account by clicking here and wait for approval from Administrator. It's completely free with no hidden strings attached.
Step 2: If you have a computer problem and need some help, or just want to take part in opened discussions, simply browse Forum. Once you *Register an account, you can quickly post your questions and comments.
(*Registered Members get: free support, also, they can communicate privately with other members via PM, removal of this message, see fewer ads and much more...)
Pages: 1
  Print
Author Topic: McAfee and Wireless Problems (HP 6910p, Intel Wireless Config)  (Read 3276 times)
hazedaze
SCF VIP Member
Gender: Male
« on: 01. January 2010., 12:23:54 »
Hi All,
I have come accross a situation where by if you install McAfee v8.5 even with the latest patches and hotfixes on a HP 6910p with the Intel Wireless Config Software installed you will get a problem with the McAfee Startup service's more notibly the McAfee framework service, Update - The Problem is only apparant after a few days not imedaitely which is very strange!!
It seems as if the Intel Wireless software installs it's own Iframwrk.exe along with it's own zero config service which is required to run the wireless utility which then causes compatability issues with the startup of the McAfee Products. I have sinced uninstalled the Intel Wireless utility and all seems to be back to normal and I will monitor for the next couple of days....
P.s disabling the built in XP wireless zero config service also does nothing to resolve the issue..
Please note the system is running WinXP SP3 with all the latest Updates, As well as McAfee v8.5 Patch 8 with Hotfix running the latest DAT's
Any Updates I will post here.......
Quick Update: 02.01.2010......
I have established that when using the Windows Wireless Zero Config Service that if your wireless network is encypted using WPA (TKIP Encryption) it will keep droping the connection and that the only way round this is to use the Intel Wireless Manager which puts us back to square one, (Please note I have not tried other encryption methods like WEP as it's simply too weak) the only way the XP Zero Config service will work is when encryption is disabled. (Dam not want I wanted but hey it's all trial an error!!)
I have yet to try the HP Wireless assistant as I'm relunctunt to have to install .Net Framwork just for this one piece of Software. I am testing some other free wireless tools to see if any of them are any better.......Keep watching this space...
Problem Sorta Fixed: 03.01.2010......
3rd party wireless tools pretty much failed in what I needed them to do so I perfomed a quick restore and went about Disabling the Iframework.exe from the startup process which seems to clear the problem,(Which is not ideal) I will have to test with user rights as policies may not allow for the starting of the Iframework.exe when you click on the Wireless Icon as it's only when you click on the Intel Wireless Icon that you get the Iframework service wanting to start.
I will see If a simple delayed startup batch file will alleviate the problem not very pretty but it may have too do as Msconfig from what I know doesn’t allow you to perform delayed startup of a particular process and I dont want to have to go down the 3rd party software route as many of them are not free for corporate use and granting elivated privilages to the Iframework.exe service is obiously out of the question. Quick Update: If you can ensure you "DISABLE" the Wirless Connection within the Network Properties befor you shut down then eveything starts up ok.......um very weird. Im feeling a BIOS update next which does'nt always solve problems but I may have to go down this road. Will update with results...
Logged
 Logged
SCF Administrator
Gender: Male
Whatever doesn't kill us makes us stronger.
Google Talk
WWW
« Reply #1 on: 01. January 2010., 12:32:32 »
Thanks for notification pal.  thumbsup
I'll move this Topic to SCF "PC Help Center": http://scforum.info/index.php?action=forum
Logged
hazedaze
SCF VIP Member
Gender: Male
« Reply #2 on: 01. January 2010., 12:39:59 »
Ah Nice One
I knew there had to be a better place for this.. Cheesy
Cheers Kida...
Logged
Pages: 1
  Print
Jump to:
Enter your email address to receive daily email with 'SCforum.info - Security CENTRAL Forum' newest content:
Powered by MySQL Powered by PHP Powered by SMF | SMF © 2011, Simple Machines
TinyPortal © Bloc
Valid XHTML 1.0! Valid CSS!
Google visited last this page 20. May 2012., 13:02:32
