Author Topic: Airy AntiSpyware: some more info  (Read 19138 times)
« on: 10. August 2013., 20:19:27 »
Some more copy pastes and thoughts about AAS - a new program for me...
Free / unregistered PRO version does NOT update! Current download version comes bundled with definitions for July 7th 2013... Not good! ALSO, unregistered version opens a new browser window / tab once in a while. Luckily, registration, for now, still is free after some easy promo work for them. I do like the program, but these details prevent it from making it a default tool. Bwerg ;p
Scanning my memory showed all clean, even when I have some obscure tools running.
Scanning hard drive took a long time: results in the reply. All in all, not too bad.
Also Copy Paste FROM: http://www.airyantispyware.com/antispyware-pro.htm
Airy AntiSpyware Pro v 2013 08 09 (Advanced AntiVirus tool )
Feature Function :
Memory Scan: Scan all the applications and processes in the memory, all the modules called in the memory and key positions of memory and system, to ensure the security of your memory.
Disk Scan: Scan the whole disk thoroughly for you to ensure the security of the disk.
System Info : Optimize the memory to ensure the system performance.
Submit Files: In case you encounter unrecognizable suspicious programs or threats, you can submit to us for analysis. We will deal with the submitted files and add them the database in case they are real threats.
System Manager
Inspect Process: Inspect all the running system processes, and if you think some items are suspicious, you can choose to end them.
Inspect Startup: Monitor all the system startups, and you can easily disable the selected ones.. Inspect Service.: Inspect and manage all the system services easily.
System Report: Check the Windows system processes, startups, services, drivers, and IE browser related information of the computer, to analyze whether your computer is at risk. Once suspicous objects detected, you can Submit the suspicious files to the technicians for confirmation.
White List: White List function cover Suspicious files quarantine, exclude, and malicious website blocking.
Advanced Functions
Quarantine: Quarantine is the place to isolate the threats. You can restore the selected threat, add them to white list or clear them.
System Repair: Provide you with reocovery solution for some commonly encounted issues.
Enhanced Uninstall: Deal with those programs that cannot be uninstalled through the regular way.
ARP Bundle: The bundle of gateway IP and MAC address enables you to avoid network failures caused by ARP attack. So, we recommend the bidirectional bundle at gateway and router for better performance. The function suits only the LAN users.
More Utilities
IE Repair: Repair the changed or destroyed IE browser, clean IE buffer and history records.
Network Status: Check the current network connection status, terminate selected process. Assistant Tools: The tools include file shredder, suspicious files extraction and other system tools.
Detection Logs: Check the detection and threats killing records.
Flash Drive Viruses Immunity: The auto run of CD-ROM and flash drives provides the opportunity for threats spreading and infection. Enable the immunity function will effectively stop the spreading of this kind of threats.
Difference with free version? Automatic Priority Updates and Tech Support, that's it!
Also see promo: http://scforum.info/index.php/topic,7619.msg21161.html#msg21161
Help me help you! https://copy.com/?r=zOEhNk - Clear 15GB of cloud storage and... 
... karma for you :)
Re: Airy AntiSpyware: some more info: scanresults
« Reply #1 on: 11. August 2013., 21:19:54 »
Many false positives... Auto-moved to Quarantaine. You can whitelist found false positives... But only one by one :(
Threat found through disk detection:->Backdoor.Win32.IRCBot #116835
C:\C\- KLAAR\portapps\DVDDecrypter 3.5.4.0.exe
Threat cleared successfully!
Threat found through disk detection:->Backdoor.Win32.Bifrose #74320
C:\C\- KLAAR\Windows System _Recovery_ cleaning tools\Backup 4 all Professional 3.10.289 + Patch\Backup 4 all Professional 3.10.289.exe
Threat found through disk detection:->Trojan.Agent #70936
C:\Program Files (x86)\Glarysoft\Glarysoft Giveaway\TaskScheduler.exe
Threat found through disk detection:->Trojan.Win32.Generic.12B5BE5E #122634
C:\Program Files (x86)\HideIPVPN\Uninstall.exe
Threat found through disk detection:->Trojan.Win32.Generic.129D03DF #118934
C:\Users\Phoenix\Desktop\Dropbox\for Dave-pc\USB Stick LMC\Torpark\Torpark 1.5.0.7\Torpark.exe
Threat found through disk detection:->Packed.PolyCrypt.amfy #117588
C:\Users\Phoenix\Downloads\== TOR\Windows 7 Home Premium (32 Bit)\Windows 7 Activation\Windows 7 Activation.exe
C:\Users\Phoenix\Downloads\== TOR\Windows 7 Professional (32 Bit)\Windows 7 Activation\Windows 7 Activation.exe
C:\Users\Phoenix\Downloads\== TOR\Windows 7 Starter (32 Bit)\Extra Activation Programs\Windows Loader 1.9.5 (Reccomended)\Windows Loader 1.9.5 (Reccomended).exe
C:\Users\Phoenix\Downloads\== TOR\Windows 7 Ultimate (32 Bit)\Extra Activation Programs\Windows Loader 1.9.5 (Reccomended)\Windows Loader 1.9.5 (Reccomended).exe
C:\Users\Phoenix\Downloads\== TOR\Windows Vista Business SP2 (32 Bit)\Windows Vista Activation\Windows Vista Activation.exe
C:\Users\Phoenix\Downloads\== TOR\Windows Vista Home Basic SP2 (32 Bit)\Windows Vista Activation\Windows Vista Activation.exe
C:\Users\Phoenix\Downloads\== TOR\Windows Vista Home Premium (32 Bit)\Extra Activation Programs\Windows Loader 1.9.5 (Reccomended)\Windows Loader 1.9.5 (Reccomended).exe
C:\Users\Phoenix\Downloads\== TOR\Windows Vista Home Premium (32 Bit)\ISO File\Windows Vista Activation (Reccomended)\Windows Vista Activation (Reccomended).exe
C:\Users\Phoenix\Downloads\== TOR\Windows Vista Home Premium SP2 (32 Bit)\Windows Vista Activation\Windows Vista Activation.exe
Threat found through disk detection:->Trojan.Small.edz #47775
C:\Users\Phoenix\Downloads\== TOR\Windows XP Home\Extra Unique Programs\XP Key Recover And Discoverer 5.12.EXE
C:\Users\Phoenix\Downloads\== TOR\Windows XP Professional (32 Bit)\Extra Unique Programs\XP Key Recover And Discoverer 5.12.EXE
C:\Users\Phoenix\Downloads\== TOR\Windows XP Professional Corporate (32 Bit)\Extra Unique Programs\XP Key Recover And Discoverer 5.12.EXE
C:\Users\Phoenix\Downloads\=== FOLDERLESS OLDER DOWNLOADS\HideIPVPN-v1.0.0.2-install.exe
C:\Users\Phoenix\Downloads\=== FOLDERLESS OLDER DOWNLOADS\HideIPVPN-v1.0.0.3-install.exe
C:\Users\Phoenix\Downloads\=== FOLDERLESS OLDER DOWNLOADS\HideIPVPN-v1.0.0.4-install.exe
C:\Users\Phoenix\Downloads\=== FOLDERLESS OLDER DOWNLOADS\HideIPVPN-v1.0.0.5-install.exe
C:\Users\Phoenix\Downloads\=== FOLDERLESS OLDER DOWNLOADS\ibVPN-openvpn.exe
Threat found through disk detection:->Trojan.Win32.Generic.12ADEAD8 #126309
C:\Users\Phoenix\Downloads\=== FOLDERLESS OLDER DOWNLOADS\NetStumblerInstaller_0_4_0.exe
C:\Users\Phoenix\Downloads\billing.hideipvpn.net\HideIPVPN-v1.0.0.4-install.exe
C:\Users\Phoenix\Downloads\billing.hideipvpn.net\HideIPVPN-v1.0.0.5-install.exe
Threat found through disk detection:->Backdoor.Trojan #105146
C:\Users\Phoenix\Downloads\Windows 8 Activation Customization Pack Incl build 9200 ~HuNtEr~\setup\Windows 8 Activation Customization Pack\Win8_Activation_Reset.exe
drive C:\ Scan Completed.
Start Scanning The Removable Drive A: ...
drive A:\ Scan Completed.
Scanned Files:646018 Threat Found:26
Not too bad, I will keep it running besides Avast Home & Zemana... Scan took a long time (>5 hours, 1TB)
Karma!
Devnullius
« Reply #2 on: 14. August 2013., 10:42:40 »
D. you write this Topic on 10.08. and this App use definitions from 07.07. ?!  :-X
"One of the most frequently asked questions we get is: “How many viruses do you find every day?”.
At first you may laugh – but you shouldn’t. No. Here I should remind you (forgotten your better schoolteachers’ words?) that there’s no such thing as a stupid question! So what do I do with this question – simple though it seems? Answer with a simple answer. Right? But I thought that the answer was the much bandied about figure that we’ve had for a while – 35,000 viruses a day. Or somewhere in that vicinity, on average, and without going into mind-numbing detail about malware families, polymorphism, vector patterns, peculiarities of counting database records, etc."
Source (relevant): http://eugene.kaspersky.com/2011/10/28/number-of-the-month-70k-per-day/
Definitely!  :down:
« Reply #3 on: 14. August 2013., 11:31:43 »
The free, unregistered version, yes, it does not update and currently had definitions dating from July...
BUT you can easily get Pro key by promoting them: look at their page. I'm still testing the software... Expect some later edits ; )
D.
« Reply #4 on: 15. August 2013., 09:24:29 »
It'll be very hard to make some success with this concept, when you have competitors like: Malwarebytes, Spybot S&D, SUPERAntiSpyware etc.
Don't know why but I'm really skeptical with this App, site is very "poor" with information with some "nonsenses":
1. About Airy AntiSpy Software: http://www.airyantispyware.com/company.htm
"Airy AntiSpyware is one of the leading Business Groups of the country with an innovative approach."
Which Country? I can't find any Company address anywhere... :thumbsdown:
2. Features & Benefits: http://www.airyantispyware.com/
"Remove Special Virus"
WTF is "Special virus" ?!  ???
That's just my two cents...
« Reply #5 on: 15. August 2013., 09:43:25 »
:) it looks like a one-man-trick, true.
His English is horrible (email gave me a faMMily key... I wrote him, and corrected some more errors for him. He's working on it, but me being Dutch wasn't good enough for him ;p
For me, biggest test is false positives. It does not have many. that's good. But it's either because it can't detect anything or because of quality. In the latter case, if detection would become better, false positives could rise. I've seen it happen before. But for now: looks good, details still to follow ;p
« Reply #6 on: 15. August 2013., 12:05:49 »
Honestly, the only reason for me to believe in this App is yours faith in it...  ;)
Do not get me wrong, I support the effort and commitment of all the people who try to honestly earn. In the end, he makes no effort to earn through online scams, etc. :thumbsup:
I know that my English is bad as well...  ;D
Re: Airy AntiSpyware: some more info: contact with support...
« Reply #7 on: 19. August 2013., 14:02:41 »
Today I again asked support for this program. I'm a patient girl, sometimes ;p
I also had a problem that the key was not remembered, but that seems to be fixed in the latest update a few days ago (...)*
Copy Paste of contact with support:
"Hello,
Your program comes with a startup blocker. At startup, a notification appears for some applications that they will be auto-blocked unless specified otherwise.
Also there is an option to remember your choice.
Problem 1: choices are NOT remembered.
Problem 2: despite the default value to block, the programs will start nonetheless. Which seems to me the startup blocker is not working at all?
Problem 3: on windows 8 x64 I must give permission to Airy program itself when I boot the computer. Again, making it appear it is not an effective antivirus if it is started so late...? Please explain :)
I'll also post information on scforum.info. I will add your reply to that discussion.
Devvie Nuis,
NL"
Their reply: <TO BE EDITED>
* you can say it Samker ; )
« Reply #8 on: 20. August 2013., 09:07:02 »
No, no... I'll give him (and you) few more days for reply.  ;D
Who knows...
akwork
« Reply #9 on: 23. August 2013., 06:06:03 »
is new software,has Active Defense . Lower right corner of the desktop will pop up tips.
and Update Frequency Quickly!
