Forum > Firewall
Test Your FireWall Protection !!!
Payam20:
Good test...Thanks!
Duar97:
Hi...
I did the GRC test and the results were this:
GRC Port Authority Report created on UTC: 2011-08-27 at 16:53:31
Results from scan of ports: 0-1055
1 Ports Open
4 Ports Closed
1051 Ports Stealth
1056 Ports Tested
The port found to be OPEN was: 23
Ports found to be CLOSED were: 0, 1, 20, 21
Other than what is listed above, all ports are STEALTH.
TruStealth: FAILED - NOT all tested ports were STEALTH,
- NO unsolicited packets were received,
- A PING REPLY (ICMP Echo) WAS RECEIVED.
Can you help me... I'm using COMODO Firewall
Regards, Duar97
jheysen:
Download the Sysinternal suite and use TCPView to check witch application is listening on port 23.
J.
okbetsports:
play and earn check this OKBET
Navigation
[0] Message Index
[*] Previous page
