  • Total Topics: 16149
Author Topic: Bitcoin Forecast  (Read 3743 times)
MelissaLiberson
  • SCF Hero Member
Bitcoin Forecast
« on: 19. February 2019., 13:53:23 »
BTC is truly on the rise since a last few days. There is every chance that we might see it crossing 4k mark, but the more important part that’s to be looked at is whether it can hold and if the upward movement sticks. IF that happens then Sky is the limit as far upper level is concern.
Bitcoin Forecast
MelissaLiberson
  • SCF Hero Member
Re: Bitcoin Forecast
« Reply #1 on: 24. March 2019., 15:31:27 »
Bitcoin stayed below 4k levels, although we did saw it breaking pass in a minor way, but was far from anything noticeable. It’s a level that’s looked with high interest, because that could decide up for the direction of the market. It won’t be a bad time to go for buy here.
MelissaLiberson
  • SCF Hero Member
« Reply #2 on: 26. April 2019., 16:02:54 »
Bitcoin has went into low gear once again along with rest of the Cryptos, but as long as it remains above the 5k barrier, it’s still not anything to be highly concern about for people and should make the move for bullish trend to take up.
MelissaLiberson
  • SCF Hero Member
« Reply #3 on: 23. May 2019., 04:02:49 »
Bitcoin is slightly down in last few days, but overall, there is still a push for going towards 8k mark. It is likely that we will that crossed in coming weeks. It will be good opportunity to take a shot at this point.
MelissaLiberson
  • SCF Hero Member
« Reply #4 on: 20. June 2019., 18:03:57 »
Bitcoin as we have seen moved pretty much on the topside. It is highly likely that we will see it challenging the massive 10k mark at some point in coming weeks. So it for sure to be a good opportunity to go for long here, especially if you could afford to be patient.
MelissaLiberson
  • SCF Hero Member
« Reply #5 on: 19. July 2019., 23:41:09 »
BTC had a very bad fall in recent days, as it went below 10k mark for the first time since June, it is highly likely to stay around this mark. It could be risky but a good trade to go for buy here with a lot of pips on for grabs.
