  • Total Members: 14176
  • Latest: toxxxa
  • Total Topics: 16072
  • Online Today: 1383
Author Topic: The "fraud monitoring is on" will not come up on my computer.  (Read 32612 times)
cobaltazule
Re: The "fraud monitoring is on" will not come up on my computer.
« Reply #20 on: 29. August 2007., 15:49:03 »
samker
 My version of norton 360 is up to date and my subscription is good. It is also updated everyday. It tells me there is no infection. I ran the trend micro scan and fix as you asked and it only found a few low grade items. The "fraud monitoring is on" bar still does not work. I have provided that new log file as you asked. I hope it helps. I honestly, at this point don't know what to do. Nothing seems to work to restore it. Again, thanks for your patience.
« Reply #21 on: 29. August 2007., 16:02:45 »
Ok, that's good. We don't have any infection.  8)
Now we will do this: Start > Control Panel > double-click Add/Remove Programs > Click Norton 360
I think that you will find there option Repair, choose that and folow instruction.
After that post here what's happend. I will be here in about two hours again.
cya later,
cobaltazule
« Reply #22 on: 29. August 2007., 23:11:53 »
I will do as you ask, but can I do it in "safe" mode? I do not want to lose my norton.
« Reply #23 on: 30. August 2007., 06:12:38 »
Don't worry you won't lose anything with this repair.
cobaltazule
« Reply #24 on: 30. August 2007., 07:15:31 »
samker, I did as you asked. My system will only remove it. It will not "repair" as you ask. I tried it and almost lost my norton 360. I was one click away from having to purchase another software package. I cannot afford to do that. Is there any way to find the part of my system that was damaged. If I can do that I can then attempt the repair.
« Reply #25 on: 30. August 2007., 07:18:10 »
Ok, do you maybe have Norton orginal instalation CD ?
« Reply #26 on: 30. August 2007., 07:33:32 »
Also, I have two more solutions:
1. First go to Control Panel and just look is there separate Norton Toolbar (or something called fraud monitoring). Don't change anything just inform me.
2. Second is to reset Internet Explorer to Default Settings: Tools > Internet Options > Advanced > and (Finaly) reset.
« Reply #27 on: 30. August 2007., 07:38:07 »
to Kevin76:
Kevin,
if you have any suggestion you'r are wellcome to include in resolving this problem.
Security l33t
  • SCforum's Security Manager o.0
    • Security Central Forum
« Reply #28 on: 30. August 2007., 14:44:22 »
Can't you just reintall with same key?, i think it's located in pc even if you reintall, but i recommend you to print the key anyway, (it's a function within Norton to print you cd key :D)
« Reply #29 on: 30. August 2007., 14:59:21 »
Hi Security...,
did you have experience with this Norton version?
It's look like we will need help from someone who try this version and check is problem inside of Norton or IE.
