Steps to turn off System Restore1. Click Start, right-click My Computer, and then click Properties.2. In the System Properties dialog box, click the System Restore tab.3. Click to select the Turn off System Restore check box. Or, click to select the Turn off System Restore on all drives check box.4. Click OK.5. When you receive the following message, click Yes to confirm that you want to turn off System Restore:You have chosen to turn off System Restore. If you continue, all existing restore points will be deleted, and you will not be able to track or undo changes to your computer.Do you want to turn off System Restore?After a few moments, the System Properties dialog box closes.
Hi, Sorry for the late reply...
- Open: My Computer -> C:\ -> Documents and Settings -> All Users (now open Tools -> Folder Options -> View (find this option "Show hidden files and folders" turn on this option and click Ok). - After that open: Application Data -> Symantec -> Norton AntiVirus -> Quarantine (delete everything you find there).- When you finish this go again in Folder Options and turn of "Show Hidden files and folders"
O2 - BHO: Adobe PDF Reader Link Helper - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelper.dllO2 - BHO: SSVHelper Class - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre1.6.0_05\bin\ssv.dllO2 - BHO: (no name) - {7E853D72-626A-48EC-A868-BA8D5E23E045} - (no file)O4 - HKLM\..\Run: [preload] C:\Windows\RUNXMLPL.exeO4 - HKLM\..\Run: [PCMService] "C:\Program Files\Acer\Acer Arcade\PCMService.exe"O4 - HKLM\..\Run: [SunJavaUpdateSched] "C:\Program Files\Java\jre1.6.0_05\bin\jusched.exe"O4 - HKLM\..\Run: [ImInstaller_IncrediMail] C:\DOCUME~1\MALYNA~1\LOCALS~1\Temp\ImInstaller\IncrediMail\incredimail_install.exe -startup -product IncrediMail -cluster 1O4 - HKLM\..\Run: [RegistryMechanic] C:\Program Files\Registry Mechanic\RegMech.exe /QSO4 - HKLM\..\Run: [QuickTime Task] "C:\Program Files\QuickTime\qttask.exe" -atboottimeO4 - HKLM\..\Run: [Adobe Photo Downloader] "C:\Program Files\Adobe\Photoshop Album Starter Edition\3.2\Apps\apdproxy.exe"O4 - HKLM\..\Run: [Adobe Reader Speed Launcher] "C:\Program Files\Adobe\Reader 8.0\Reader\Reader_sl.exe"O4 - HKLM\..\Run: [KernelFaultCheck] %systemroot%\system32\dumprep 0 -kO4 - HKCU\..\Run: [updateMgr] C:\Program Files\Adobe\Acrobat 7.0\Reader\AdobeUpdateManager.exe AcRdB7_0_9O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0_05\bin\ssv.dllO9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0_05\bin\ssv.dllO23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Program Files\Common Files\InstallShield\Driver\1150\Intel 32\IDriverT.exeO23 - Service: Cyberlink RichVideo Service(CRVS) (RichVideo) - Unknown owner - C:\Program Files\CyberLink\Shared Files\RichVideo.exeO23 - Service: Symantec Core LC - Unknown owner - C:\Program Files\Common Files\Symantec Shared\CCPD-LC\symlcsvc.exe
