  • Online Today: 4556
Author Topic: eSoftTools EML to MSG Converter  (Read 10083 times)
roy
« on: 26. August 2019., 11:22:01 »
The ultimate option for EML migration into Outlook is eSoftTools EML to MSG converter software. It lets the user to provide an interface where user can select EML file from the folder on its own and then export them into MSG or Office 365 file type. Any huge EML file can also be recovered with all email and its components such as bcc, cc, to, from, subject, attachments, etc. One can try it for free by using free demo of the tool from official website of eSoftTools.
matthew021
Re: eSoftTools EML to MSG Converter
« Reply #1 on: 18. September 2019., 08:04:06 »
MailsClick Convert EML file to PST Software which can also convert your all EML file of different email clients like windows live mail, apple mail, Mozilla Thunderbird, outlook express to Outlook PST file format. This software converts multiple files format:- PST, MSG, MBOX. It extracts all the essential email components like To, Bcc, Cc, Sent, From, Received, Attachments, etc. It also supports all version of Windows. Download the free trial version Convert EML file to PST.
Akshay_M
« Reply #2 on: 01. October 2019., 16:56:36 »
To convert the number of eml files into msg, please do following steps:
Start Outlook Import Wizard utility
Type in the full path to source folder where .eml files are located or click “Browse” button and point to the source directory.
Click “Next >>” button
The software will scan selected directory and all sub-folders (if the recursive function turned on), find all .eml, .msg files and display them in the file list were you can deselect some items.
At this step you can configure some options and filters if you need them.
Click “Convert EML and MSG files to:” option to enable it
The information message will appear:
This option enables the conversion mode.
Do not enable this option if you want to import emails!
Press Ok to close it.
Choose the file format to which you want to convert the source emails.
Press “Start” button
Akshay
mariejohn
« Reply #3 on: 18. January 2020., 10:17:38 »
Here is another reliable and trustworthy solution i.e. VOOK EML to MSG Converter to convert/export EML files to MSG format. It can efficiently switch the files format without any data loss. It gives 100% effective and error-free results of the conversion process. The unlimited EML files in the batch form can be easily exported to MSG format at once with attachments embedded in it. The original hierarchy of the folders is well maintained by this tool throughout the migration process. It is compatible with all the EML based email clients and also supported MS Outlook editions.
Somit Vishwakarma
« Reply #4 on: 29. August 2020., 14:02:13 »
MailsDaddy EML to PST Converter is the tool to migrate EML to PST, MSG, HTML, MHTML & RTF format. You can use this tool to import EML data from WLM, OE, Thunderbird, Apple Mail and many other. It has so many features that allows user to migrate data from EML to MSG format.
mikeduke990
« Reply #5 on: 13. October 2020., 12:29:25 »
To Convert EML to MSG for Outlook:-
Install the Convert EML to MSG utility and start OutlookFreeeware.com Utilities from Windows Desktop or Start Menu.
Specify the folder with .EML or .EMLX files on your disk or network share:
Specify the target folder for resulting . MSG files.
Run the tool and wait until it finishes.
olivermiller09
« Reply #6 on: 02. November 2020., 09:00:02 »
Mailvita EML to MSG Converter for Mac Software available for the conversion of Windows Live Mail (EML) to MSG for Mac. Here I would like to recommend one more reliable utility for Mac users named EML to MSG Converter for Mac effectively converts EML file to Outlook MSG without any hurdle in Mac OS. There is no risk of losing any data of the EML file. This tool supports all MS outlook and all Mac OS versions. Download the free demo version software.
Rajat
« Reply #7 on: 30. December 2020., 09:37:47 »
If you are looking for a quick solution to convert EML to PST file format then, I would suggest using the smart EML to PST converter software which allows saving EML files in PST, MBOX, MSG, PDF, HTML, Gmail, Hotmail, Yahoo, etc. There are no file size restrictions with the utility.
Visit - https://www.data-recovery-solutions.com/eml-file-converter.php
lemidezcai77
« Reply #8 on: 17. April 2021., 12:04:34 »
You can also use the EML to MSG Converter to convert EML file to Outlook MSG format. It automatically manages folder structure, email properties, key formatting, and inline images into converted MSG file. The software has multiple useful features to export emails from EML to MSG and many other given formats. The software runs on all Windows and Outlook versions and maintains every single email into a converted MSG file. You can also try the trial version and convert few emails from each mailbox.
