  • Online Today: 4549
Author Topic: How to Get Rid of Cinavia on PS4?  (Read 6043 times)
victorhan2012
« on: 17. July 2017., 09:22:40 »
Same with PS3, PS4 cannot play back some Blu-ray movies protected by Cinavia. Blu-ray movie disc or copie contains Cinavia protection will be stopped or muted on PS4, and a Cinavia message will pop out to tell you it is protected by Cinavia. So how to get rid of Cinavia on PS4? Use DVDFab Blu-ray Cinavia Removal! This Cinavia Remover can help you bypass Cinavia on Blu-rays completely and permanently and let you enjoy Blu-ray movie freely on PS4. Now please have a look at how to remove Cinavia on Blu-ray with DVDFab Blu-ray Cinavia Removal.
Step 1: Choose the Main Movie mode
Run DVDFab 10, go to Copy module and choose the Main Movie mode
Step 2: Load the source
Insert the disc and DVDFab will load it automatically. If the source is ISO file/folder, you can load it by clicking the “add” button or dragging and dropping it to the main interface directly.
Step 3:Select the Cinavia protected audio track
Click the drop-down list under “Audio” tab to make sure the Cinavia protected audio track is checked and there is a slash across the Cinavia logo.
Step 4: Choose the output size
Click the “Advanced Settings” icon to choose the output as BD 50 or BD 25 (The output LPCM audio is large, so you can only choose BD 50 or BD 25).
Step 5: Select an output directory
Navigate to the bottom of the main interface to select a directory: to select your optical drive as the directory from the drop-down list box is to copy the Blu-ray to a disc; to select a directory by clicking the “folder” icon is to save the output as a Blu-ray folder; to select a directory by clicking the “image” icon is to save the Cinavia-free Blu-ray as an ISO image file.
Step 6: Start the removal process
Click the “Start” button to start the process of removing Cinavia.
After only a few minutes, you can enjoy your Blu-ray movie on PS3 freely without any Cinavia message code popping out.
For more details about how to do it,you can refer to this tip:http://www.dvdfab.cn/tips/get-rid-of-cinavia-on-ps4.htm
Re: How to Get Rid of Cinavia on PS4?
« Reply #1 on: 13. August 2017., 12:04:35 »
Thanks Victor, continue to post these Tips... :thumbsup:
cya around SCforum!
krishna88
« Reply #2 on: 29. January 2018., 13:41:08 »
Hi victorhan2012,
Thanks for sharing this info, about How to Get Rid of Cinavia on PS4?  :up:
Mattlevy
« Reply #3 on: 25. October 2018., 13:09:12 »
Thank you so much for sharing this information :bih:
Gfvf
« Reply #4 on: 14. October 2022., 14:52:37 »
Com qual casa de apostas está a apostar? Eu gosto, já o faço há muito tempo. Aconselho-o a usar https://mostbet-pt.com como rendimento adicional primeiro e apenas quando o rendimento aumenta, caso seja o seu rendimento principal. Isso é como se fosse uma opção. Em geral, onde encontrará as suas próprias páginas de informação para si.
