  • Total Topics: 16217
  • Online Today: 5973
Author Topic: zip archive error  (Read 11410 times)
kelvinfrost
zip archive error
« on: 26. January 2016., 18:39:36 »
Hello,
This morning I decided to open one of the zip files does not work out WinZip gave the error: "Invalid data into a Zip file."
Maybe someone knows how to solve this problem?
zip archive error
Re: zip archive error
« Reply #1 on: 26. January 2016., 23:04:36 »
You have to download the zipfile again.
« Reply #2 on: 27. January 2016., 18:28:45 »
Well, use WinRar!
It can correct little errors in acrhives and rebuild its!
It opens equally as well *.rar file as also Zip  files too!
  :up:
finleyryan
« Reply #3 on: 08. February 2016., 19:29:18 »
Please do the following to attempt to repair a Zip file or you may apply following topics in case your .zip archive is hardly corrupted
http://www.reddit.com/r/software/comments/2iqnap/zip_file_corrupt/
http://itknowledgeexchange.techtarget.com/itanswers/how-to-repair-zip-files-after-zip-archive-corrupt-or-damaged/
https://www.repairtoolbox.com/ziprepair.html Zip Repair Toolbox
Please do the following to attempt to repair a Zip file:
1.   Open an administrator Command Prompt window
Windows 10 and Windows 8.1
1.   Right click the start button
2.   Click Command Prompt (Admin)
Windows 7 and Windows Vista
3.   Click Start, click All Programs, and click Accessories
4.   Right click Command Prompt and choose Run as administrator
2.   Change directories to the folder where the corrupted Zip file is located
3.   Type: "C:\Program Files\WinZip\wzzip" -yf zipfile.zip
4.   Press Enter on the keyboard
Substitute the actual drive letter and folder where WinZip is installed if different than above and also use the real Zip file name in the place of zipfile.zip. The double quotes in the example above are necessary due to the space between "Program" and "Files".
For a split or spanned Zip file, use the following command instead:
"C:\Program Files\WinZip\wzzip" -yfs zipfile.zip
WZZIP will create a new Zip file with a FIXED suffix in the file name. The original Zip file will not be modified. Only the data in the original Zip file is used.
The FIXED Zip file is structurally sound but the data may still be corrupt. WZZIP does not fix the zipped data itself. If the zipped data has a CRC error or the zipped data is corrupt, then the resulting fixed Zip file will still be corrupt.
Pitti1960
« Reply #4 on: 15. October 2016., 08:15:50 »
Mit Winrar hast Du die Möglichkeit, defekte Archive, z.B. zip, rar, zZ etc. zu reparieren. Funktioniert nicht immer, aber oft schon hat es mir geholfen.
WeAreScrewed
  • WeAreScrewed
« Reply #5 on: 18. October 2016., 15:00:42 »
7-Zip is open source and possibly the best archiving software out. Has better compression ratio and the command line is very simple to learn to generate automated scripts if required.
http://www.7-zip.org/
Sent from Somewhere
rohanwiese
« Reply #6 on: 02. May 2018., 14:23:43 »
You can get solution to fix zip file error https://www.arysontechnologies.com/archive-recovery.html
