Author Topic: Appearance on my android phone & slowness  (Read 10896 times)
Danielx64
    • Danielx64
« on: 08. January 2017., 09:28:28 »
My only issue is that this forum doesn't really display that nice on my android phone. Also it seens to be slow for me some reasons.
Update:
Via pm I provided screenshots about how the forums look on my phone. being honest it just doesn't look pretty.
I am finding that I need to do an awful lot of scrolling- not just up and down but sideways. Also topics are hard to read as well - like the below image:
Now that only the first post, when you get down to having quotes it start to get to the point where things become unreadable.
Now there is 2 ways that this issue can be fixed - try and fix the SMF theme, something that I wouldn't be able to help too much with (as I don't have the skills to deal with SMF themes) or there is an option of switching to another forum software. I know that may sound crazy just for one thing but I will leave some reasons why switching it not always a bad thing.
First up a small disclaimer, I'm a co-author of php-bbdr a fork of phpBB.
With that disclaimer out of the way, there is some advantages to switching
- The default theme is completely responsive: no matter what device you are on the theme will adjust to suite the screen size
-Nicer looking urls: Instead of having a url that looks like (http://scforum.info/index.php?topic=12704.msg33822;boardseen#new) it would look like http://scforum.info/?topic-hello-all-12704.
Last thing that I would touch on, not sure if you guys would make use of it but emoji are supported.
So to sun it up I just wanted to leave my comments about how this forum shows up on a android phone :)
Even if you decide not to switch I would still provide pictures on how things shows up on my phone :)
Edit: I found I have I have to go into code mode to clean up all the mess that was created while editing this post.
Re: Appearance on my android phone & slowness
« Reply #1 on: 08. January 2017., 12:07:26 »
Pal,
Thank you very much for the feedback. :thumbsup:
Until you provide more detailed comment and screenshots (as We agreed in conversation via PM ;) )... I'll try to explain situation with periodic slowness.
The main reason is that We changed hosting before few Weeks: http://scforum.info/index.php?topic=8415.msg21612#msg21612 and that I, because of my full time job and private life, don't have enough free time to "tweek everything on the right way". :-/
I promise, I'll finish that, ASAP. :police:
Regarding first thing, I'm waiting for your next reply or edit... also, comments from other members are welcomed.
cya later,
Danielx64
    • Danielx64
« Reply #2 on: 09. January 2017., 08:44:21 »
Hi Sam (not sure if you like being called that),
I've updated my first post and I also provided an extra image on how a topic is viewed :)
Thank you :)
Also the forum is not too bad now :)
« Reply #3 on: 10. January 2017., 20:20:11 »
Hi again Daniel,
As you probably noticed till now, English isn't my first language... and because of that I have some difficulties when need to write little bit longer replies... I'm sorry for all the past and future mistakes and misunderstandings. :-\
Regarding your comment about displaying on smartphones - I must to admit that I totally agree with You and that is one of the must to do things - however, it'll need to wait until I get little bit more of free time. Right now, I work for two companies and here is even more important detail: http://scforum.info/index.php?topic=11683.msg31870#msg31870
(Also, the most of our members still browses site via PCs - cca 95%.)
FYI, the main reason for bad displaying isn't "Simple Machines" forum, instead of it, problem is with "Tiny Portal": http://www.tinyportal.net - which We must to use because of a huge number of other benefits and functionalities.
As you correctly presume, changing SMF isn't option at the moment... however, I want to congrats on your work and wish you huge success. Also, since you're expert in your field - from now on, you'll have VIP membership. :police:
Thank you for understanding... also, I hope that you'll become active member of our Community.
cya around,
I'm glad that you notice that - since I finished 90% of necessary tweeks during a Weekend. ;)
Danielx64
    • Danielx64
« Reply #4 on: 11. January 2017., 09:19:17 »
Hi again Daniel,
It's all good, I deal with people who English is not their first language before so it not new to me before :)
[/size]
FYI, the main reason for bad displaying isn't "Simple Machines" forum, instead of it, problem is with "Tiny Portal": http://www.tinyportal.net - which We must to use because of a huge number of other benefits and functionalities. [/size]
That's fair enough- I understand that you have 2 different jobs (it's the same with me as well).
[/size]
cya around,
Thank you for the kinds words. I understand that switching from SMF is not an option: every forum is different :). Thank you for the VIP pass and yes I will be active when I am able to :)
