free 'Online Armor' I find it harder to recommend products today than how it used to be. With so many sec tools available now (mostly scams), it is harder to pick and choose. Also, when recommending products, the user abilities must be a consideration. I can't recommend the tools I use as an end point solution because they are designed for admin and not the casual user...like the Snort IDS(host based). This leaves me a little bit out of touch with common use. However, I've been doing some recent informal testing of some of the more respected tools in the HIPS category. Of the products examined so far, I find OnlineArmor to be the most user friendly and with equal or better HIPS protection. It also has a strong user base and plenty of help and refs. HIPS filtering/firewalling is essential today. Remember; " If it can't initiate, it can't infect." BTW OnlineArmor also has what I consider a prerequisite for any HIPS tool, a 'learning mode'.I think that's about 2c worth.
I posted this elsewhere just a few days ago. I hope no one will mind if I just do a paste;Quotefree 'Online Armor' I find it harder to recommend products today than how it used to be. With so many sec tools available now (mostly scams), it is harder to pick and choose. Also, when recommending products, the user abilities must be a consideration. I can't recommend the tools I use as an end point solution because they are designed for admin and not the casual user...like the Snort IDS(host based). This leaves me a little bit out of touch with common use. However, I've been doing some recent informal testing of some of the more respected tools in the HIPS category. Of the products examined so far, I find OnlineArmor to be the most user friendly and with equal or better HIPS protection. It also has a strong user base and plenty of help and refs. HIPS filtering/firewalling is essential today. Remember; " If it can't initiate, it can't infect." BTW OnlineArmor also has what I consider a prerequisite for any HIPS tool, a 'learning mode'.I think that's about 2c worth.
Thanks Mike. "Because of" your recommendation, I'll add (sticked) "Online Armor Free" Topic to SCforum's Firewall area (with Comodo & ZoneAlarm). Quote from: mikey on 21. February 2012., 18:28:47I posted this elsewhere just a few days ago. I hope no one will mind if I just do a paste;Quotefree 'Online Armor' I find it harder to recommend products today than how it used to be. With so many sec tools available now (mostly scams), it is harder to pick and choose. Also, when recommending products, the user abilities must be a consideration. I can't recommend the tools I use as an end point solution because they are designed for admin and not the casual user...like the Snort IDS(host based). This leaves me a little bit out of touch with common use. However, I've been doing some recent informal testing of some of the more respected tools in the HIPS category. Of the products examined so far, I find OnlineArmor to be the most user friendly and with equal or better HIPS protection. It also has a strong user base and plenty of help and refs. HIPS filtering/firewalling is essential today. Remember; " If it can't initiate, it can't infect." BTW OnlineArmor also has what I consider a prerequisite for any HIPS tool, a 'learning mode'.I think that's about 2c worth.
The best Firewall at the market is:1. Cut the powercord,2. disassemble the battery,3. cut the internet cable,4. unplug the GSM, 3G, 4G (or what ever) modem and router from the internet that you have connection to, disassemble also all hard drives.5. Go to your local (Swiss or other land with high bank security outside US and EU) Bank and lock in everything in you rented Banksafe.This is not 100% prof but it is currently one of the safest Firewall on the market. ;)Important to know you compromise's the system again if you or someone else open the Banksafe or move it to a other country or a other regime.Note also my signature below ;) :
And your signature... Is this a rude sex metaphore? Not amused!)Peace!devnullus
