...it only has two processes and uses less than 20MB of RAM...
As you can see there is a folder named 'Safe Run shared folder'. This folder is a special folder created by Kaspersky security product to execute or run suspicious files - in other words, it is a sandbox. Which means, you can run any suspicious files and it will not harm you computer as it is 'sandboxed'.
This is unbelievable small number.
By the way, Samker, assuming you are using VSE 8.7, how much RAM does it consume on your machine? Just curious
