  • Total Topics: 16079
  • Online Today: 3869
Author Topic: MAIL PROBLEMS.  (Read 30473 times)
Re: how to start Outlook in Safe Mode and disable add-ins
« Reply #10 on: 30. May 2015., 08:45:44 »
Yes, When The Problem Started, One Of The Very First Things I Did Was The Repair Option - No Luck.
Hmmm... well, maybe some Add-ins cause these problems.
Let's try on this way:
- Start Outlook in Safe Mode:
- Hold the CTRL button on your keyboard when clicking the Outlook shortcut on your Desktop, Start Menu, Start Screen or Taskbar, Outlook will detect this and asks if you want to start Outlook in Safe Mode.
*This method works in all versions of Windows and for all versions of Outlook.
If you are able to work without any issues then it is due to problem with add-ins.
- If that is the case, follow the steps below and disable add-ins in Outlook 2003:
1. Tools-> Options…-> tab Other-> button Advanced Settings…
2. Press the “Add-In Manager…” or “COM Add-Ins…” button depending on which add-ins you want to enable/disable
3. For some add-ins you’ll need to restart Outlook for changes to take effect.
- If the above step does not fix the issue, create new profile and check on that way: https://support.microsoft.com/en-us/kb/829918
cya later,
MAIL PROBLEMS.
« Reply #11 on: 30. May 2015., 09:34:39 »
Very Good Tips.
I Will Try Them Within A Week.
Thank You.
« Reply #12 on: 31. May 2015., 10:00:22 »
Very Good Tips.
... and provide us a feedback. ;)
MAIL PROBLEMS.
« Reply #13 on: 02. June 2015., 03:49:48 »
I Unchecked These 3 Extensions.
So Far, So Good.
Thank You.
Re: how to disable Outlook's add-ins?
« Reply #14 on: 06. June 2015., 11:27:38 »
So Far, So Good.
Problem solved?
MAIL PROBLEMS.
« Reply #15 on: 06. June 2015., 16:46:23 »
I Really Believe This Problem Belongs To The Past, Now.
Thank You So Very Much.
Re: MAIL PROBLEMS.
« Reply #16 on: 07. June 2015., 18:37:13 »
I hope so... 8)
You are very Welcome.
M$ OUTLOOK 2003 PROBLEMS ( PART2 ).
« Reply #17 on: 27. January 2017., 17:11:33 »
Hello,
In The Last Few Days I Changed ISP Providers.
I Had An ADSL Connection With The Old 1, And, Now, I Have A FIBER Connection With The New 1.
I Can Send Messages, But I Can Not Receive Any.
I Get Error Code 0x800408fc.
Is It Related With IPV6, Or Something ?
Any Help Would Be Appreciated.
Thank You.
Re: MAIL PROBLEMS.
« Reply #18 on: 27. January 2017., 19:47:35 »
Maybe this will help: https://social.technet.microsoft.com/Forums/office/en-US/b32b2b37-7851-44a9-b9e1-058e415c4ff7/error-0x800408fc-in-outlook-2010?forum=outlook
So yup, it might be an IPv6 related error if your ISP gives you an IPv6 Address but you haven't installed IPv6 support on your computer.
« Reply #19 on: 28. January 2017., 03:00:55 »
Thank You.
