  • Total Topics: 16218
  • Online Today: 5974
Author Topic: [Q] Registry key totally locked :( How to remove?  (Read 8194 times)
« on: 07. March 2014., 21:03:30 »
FROM: http://www.*** Domain blocked by Admin ***/viewtopic.php?f=7&t=2782
It seems that Softether was the cause of a BSOD hunting me for a long time. I always suspected a VPN application, now I know :( See: http://scforum.info/index.php/topic,8903.msg23656.html#msg23656
Anyways, I removed the software with IObit Uninstaller and manually went to my registry and searched for more traces, which I found but could not remove!
Also, removing the device "VPN Client Adapter - VPN123" fails. No error, but removing it will not work.
Seems to be in par with the fact that I cannot remove the following registry key: HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Enum\ROOT\NET\0000\Properties
It is TOTALLY blocked. I tried all regular stuff (taking permission, resetting permissions, removing inheritance, ...) but NOTHING. I also tried to remove the key with RegASSASSIN (https://www.malwarebytes.org/regassassin/).
So... Pretty please, developers... Is there an uninstall tool or *any* advise to remove this stubborn registry keys...?
Duplicate in:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\ROOT\NET\0000\Properties
Please help :)
... Peace!
Cuisvis hominis est errare, nullius nisi insipientis in errore persevare
All spelling mistakes are my own and may only be distributed under the GNU General Public License! – (© 95-1 by Coredump; 2-014 by DevNullius)
Re: [Q] Registry key totally locked :( How to remove?
« Reply #1 on: 08. March 2014., 00:56:29 »
Silly idea: Did you try to remove it from safe mode?
« Reply #2 on: 08. March 2014., 08:49:52 »
Great idea! No :)
Will do once I need to reboot PC again. I'll be back in a few days ;p
GOOD tip!
« Reply #3 on: 08. March 2014., 14:24:13 »
Great idea! No :)
Usually the easiest solutions are also the best solutions. ;)
Also think about HJT: http://scforum.info/index.php/topic,785.0.html
« Reply #4 on: 08. March 2014., 23:26:33 »
More feedback from: http://www.*** Domain blocked by Admin ***/viewtopic.php?f=7&t=2782&p=5740#p5737 (qupfer)
I know, not helpfull^^
But the "locked" registry-key looks like normal windows behavior. For example, the Properties of my VirtualBox Adapter are locked too. But deinstalling the VPN-Adapter from the GUI-Tool removes the registry entry complety....so yes. You have a problem ;)
And I know that sounds like "Have You Tried Turning It Off And On Again?"
(http://www.youtube.com/watch?v=nn2FB1P_Mn8) but have you tried to re-install the driver? I mean the function in the client tool.
« Reply #5 on: 09. March 2014., 11:38:12 »
D. sorry for OT, please ask them to unblock our domain (next quote is from your first post at VPN forum):
"It seems that Softether was the cause of a BSOD hunting me for a long time. I always suspected a VPN application, now I know :( See: URL is scforum. dumb spam filter .info / index.php / topic,8903.msg23656.html#msg23656"
« Reply #7 on: 13. March 2014., 22:30:03 »
Rebooting to safe mode did not solve it either :(
HJT?
Many fora block .info domains by default. Uphill battle I'm afraid :(
I'll contact them directly... I hope that the story will end up better than with TipRadar. ;D
« Reply #8 on: 17. March 2014., 19:19:50 »
Epilogue (copied from SE VPN User Forum): :police:
Samker77    /  Post subject: Re: Why is my domain blocked?  /  PostPosted: Mon Mar 17, 2014 5:49 pm
"Since nobody reply after few days, I'll block your domain at SCforum also!"
« Reply #9 on: 18. March 2014., 08:05:34 »
You won't win anything with this :(
It's just a fact: .info is bad, for some :(
Blocking them back... Won't solve anything ;p
:) Devvie
