  • Total Topics: 16139
  • Online Today: 4105
Author Topic: International travel and your laptop  (Read 3273 times)
« on: 29. March 2012., 08:53:10 »
Do you take precautions to protect your laptop when traveling? Follow these tips to prevent your laptop from being stolen at an airport or hotel, and “share” this story with your traveling friends.
A few precautions could prevent your laptop being stolen at the airport, in your hotel, or when you're walking down a street
Shanta Hasan asked me for advice about traveling internationally with a laptop.
Many travel concerns are identical whether or not you're crossing international borders. I'll start with those and then go on to specifically international issues.
[ Get all the details you need on deploying and using Windows 7 in the InfoWorld editors' 21-page Windows 7 Deep Dive PDF special report. (reqire registration at InfoWorld Home)]
Your laptop could be stolen at the airport, in your hotel, or when you're walking down a street. A few precautions should provide protection.
Carry it in a case that doesn't look like a laptop case. There's no reason to walk around visually screaming "I've got expensive equipment here!" When you're in public, always keep an eye or a hand on that case. No one should be able to touch it without you knowing it. If you're going to leave the laptop in your hotel, secure it. If there's a safe in your room, use that. If not, ask if it can be locked in the hotel safe. Or bring a secure laptop cable. Both Kensington and SecurityKit.com make them. If someone threatens you with violence, give them your laptop. It's not worth your life.
If your laptop is stolen, you don't want to lose more than the hardware. Protect all of your data by backing it up, and further protect your sensitive data by encrypting it.
Do a thorough backup before hitting the road, and carry a flash drive for backing up new and changed files on the road. Keep the flash drive in your pocket, not in the laptop bag. (You don't want your backup stolen with the laptop.)
I recommend TrueCrypt for encrypting your sensitive files. It's free, simple to use, and pretty-near unbreakable. At least it is if you use a strong password.
If you're traveling outside of the country, you will have to go through customs at least twice. And custom officials may have the right to examine the contents of your hard drive.
You should therefore delete anything that might get you into trouble. Sure, you could encrypt the problematic files. But if the customs officer asks if you have anything is hidden on the drive, you're safest if you can tell the truth.
You'll want to recharge your laptop on the trip, so you'll have to think about electricity. AC power plugs and voltages vary from country to country.
Voltage shouldn't be a big problem. Every laptop power adapter I've examined in the last decade can handle voltages from 100-240v. Examine the tiny text on your power brick to make sure it can handle that range.
But you will need an adapter for the plug. These are easy to find and often cost less than $10. Just use your favorite search engine to look for ac plug adapter and the name of the country.
Contributing Editor Lincoln Spector writes about technology and cinema. Email your tech questions to him at answer@pcworld.com, or post them to a community of helpful folks on the PCW Answer Line forum. Follow Lincoln on Twitter, or subscribe to the Answer Line newsletter, emailed weekly.
Orginal article: InfoWorld Home March 19, 2012 By Lincoln Spector | PC World
Re: International travel and your laptop
« Reply #1 on: 29. March 2012., 14:08:33 »
Remember !!!
If you use Windows 7 in Enteprise or Ultimate edision you have built in Bitlocker drive encryption.
BitLocker Drive Encryption
« Reply #2 on: 29. March 2012., 19:57:32 »
Great topic, very, very useful.  :thumbsup:
« Reply #3 on: 29. March 2012., 20:29:18 »
Yes,
Good topic   :thumbsup: and remember to use Bitlocker or e.g in your portable Computer!
 :up:
jasonmilsont
« Reply #4 on: 16. August 2012., 19:06:26 »
Your laptop laptop or computer is probably the most costly factor you are holding and the details it maintains is the challenging factor to substitute so it needs the right security. You want a situation developed particularly for your laptop laptop or computer dimension to make sure your laptop or computer is organised comfortable and protected.
