  • Total Topics: 16139
  • Online Today: 4096
Author Topic: Foxpro file viewer  (Read 5183 times)
AapoSipila
Foxpro file viewer
« on: 12. June 2016., 16:33:23 »
Hi,
I'm looking for possibly freeware or pay program that allows you to view a file with extension .dbt .  Any suggestions?
Thanks for any info
Foxpro file viewer
Re: Foxpro file viewer
« Reply #1 on: 18. June 2016., 11:10:05 »
Hi,
Thanks for any info
Hi,
Here you have more info and recommended Apps: http://www.file-extensions.org/dbt-file-extension
Of course, "FoxPro" is one of them. ::)
Let us know, did you succeed and with which App ??
cya later,
BryanNeilson
« Reply #2 on: 21. June 2016., 15:59:10 »
Isn’t there a file with the same name as the file with the .DBT extension but with an extension of .DBF somewhere near? The .dbt file is a memo file associated with a .dbf (dBase, Foxpro) database file. If you already have any application which will open this type of file. E.g., foxpro, dBase, Access etc. You can open the .dbf file and the application will automatically extract from the .dbt file the corresponding data. If you do not have the .dbf file then it is a little bit more complicated. The .dbt structure is basically flat text, with some pointers in it relating to the records in the original .dbf file. You can open this using notepad and extract the text which is stored in it quite easily but without the original database you do not know to which records it refers.
If.dfb file not opened or corrupted, you can use a DBF Recovery Toolbox. Maybe you will solve the issue that way. http://www.oemailrecovery.com/dbf_recovery.html
BryanNeilson
« Reply #3 on: 21. June 2016., 16:01:40 »
Refer to the following thread for some possible solutions. maybe it'll help you somehow.
https://social.technet.microsoft.com/Forums/en-US/a69b325e-c809-48c6-bf88-b90132fe0dfb/dbf-file-corrupted?forum=itprovistaapps
AapoSipila
« Reply #4 on: 24. June 2016., 14:43:04 »
Thank you guys for your feedback and help. Sorry, that long time did not respond. This is because the issue was solved and I forgot to tell.) Thank you!
Pitti1960
« Reply #5 on: 15. October 2016., 08:04:31 »
Thanks for the Support!!
