My computer seems to b running fine now....but it has been acting rather slow...i'm not sure if it is because of the virus or it just needs to b defragged...thanks again for your help
O2 - BHO: (no name) - {02478D38-C3F9-4efb-9B51-7695ECA05670} - (no file)O2 - BHO: (no name) - {2182220D-AA70-4764-B4E6-1F5BBA322C9C} - (no file)O2 - BHO: (no name) - {28202bbd-57c5-4271-bdac-29be67b2920d} - (no file)
O2 - BHO: AcroIEHlprObj Class - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 6.0\Reader\ActiveX\AcroIEHelper.dllO2 - BHO: Java(tm) Plug-In 2 SSV Helper - {DBC80044-A445-435b-BC74-9C25C1C588A9} - C:\Program Files\Java\jre6\bin\jp2ssv.dllO2 - BHO: JQSIEStartDetectorImpl - {E7E6F031-17CE-4C07-BC86-EABFE594F69C} - C:\Program Files\Java\jre6\lib\deploy\jqs\ie\jqs_plugin.dllO4 - HKLM\..\Run: [DVDLauncher] "C:\Program Files\CyberLink\PowerDVD\DVDLauncher.exe"O4 - HKLM\..\Run: [RealTray] C:\Program Files\Real\RealPlayer\RealPlay.exe SYSTEMBOOTHIDEPLAYERO4 - HKLM\..\Run: [SunJavaUpdateSched] "C:\Program Files\Java\jre6\bin\jusched.exe"O4 - HKLM\..\Run: [QuickTime Task] "C:\Program Files\QuickTime\qttask.exe" -atboottimeO4 - HKLM\..\Run: [iTunesHelper] "C:\Program Files\iTunes\iTunesHelper.exe"O4 - HKUS\S-1-5-19\..\Run: [mabisekedu] Rundll32.exe "C:\WINDOWS\system32\zukenezo.dll",s (User 'LOCAL SERVICE')O4 - HKUS\S-1-5-20\..\Run: [mabisekedu] Rundll32.exe "C:\WINDOWS\system32\zukenezo.dll",s (User 'NETWORK SERVICE')O23 - Service: Google Software Updater (gusvc) - Google - C:\Program Files\Google\Common\Google Updater\GoogleUpdaterService.exeO23 - Service: Java Quick Starter (JavaQuickStarterService) - Sun Microsystems, Inc. - C:\Program Files\Java\jre6\bin\jqs.exe
O4 - Startup: DRIV3R Registration.lnk = C:\Documents and Settings\kevin farris\Local Settings\Temp\{0E7EC0ED-A560-4F18-9326-66E7C13BF450}\{01DBF423-E27B-45DA-B7F3-F9D4DB39B1C9}\ATR1.EXE(Description: Registry key running programs on start-up from user's temporary folder.)O4 - HKLM\..\Run: [igfxhkcmd] C:\WINDOWS\system32\hkcmd.exeO4 - Global Startup: America Online 9.0 Tray Icon.lnk = C:\Program Files\America Online 9.0\aoltray.exe(Description: AOL system tray icon. Not necessary. Removing this entry will free up a small amount of system resources.)O23 - Service: Viewpoint Manager Service - Viewpoint Corporation - C:\Program Files\Viewpoint\Common\ViewpointService.exe(Description: Viewpoint Manager Service. Related to viewpoint which is usually considered foistware, usually installed with AOL. Link: http://en.wikipedia.org/wiki/Foistware)
