Two of my favorite Free AV/Rootkit killers/Scanners are: 1) TDSKiller.exe download from Kaspersky.com for latest version. It will check and clean almost all rootkits.2) NPE.exe download from Norton. This one you need to be careful with. check every entry it finds before deleting a file that is something that you need. Google the filename if your not sure. Every now and then it will give a false positive so you need to use common sense....
...Another freebee for malware is the latest SuperAntivirus Free Edition. this latest version works pretty good. ...
...hope this helps somewhat.
