..."What's Bot Revolt?Bot Revolt is malware connection detection software for Windows. Instead of scanning your files for signs of infections, Bot Revolt monitors active Internet connections. It checks to see where processes from your computer are connecting to, to which IP addresses and it then compares detected IP address with its list of malicious IP addresses, blocking connections that are in fact malicious, created by malware and viruses....
...For example: the key has to be typed manually... Copy pasting the whole key isn't possible. Little things like that......
...4. I see Microsoft and even Avast blocked! I understand Microsoft (but I do not agree), but blocking Avast...?? ...7. I think I noticed some download and page errors when filtering was enabled. BUT when disabling (and loading the page/download) and then disabling again I could not reproduce it. This must be a bug that makes it look like the websites themselves are at fault.Example? The download after registering here: http://www.avast.com/get/6gQyTmY1 . I had more hiccups. Which I hadn't before Bot Revolt. The logs show Avast etc being blocked. Not good. Especially after disable / enable, Bot Revolt should block again!*...
...8. the website mentions that BR works as a two way firewall. I have absolutely NO idea how that would work... I just don't see it! ...
