Ok... I'm in a typical home setup... To give external IP I need to bridge my ISP router to my server directly... Isn't something I'd love to do (security + RL home setup makes that a pain... Router & Server are at opposite sites of my home).Current setup:* --cable--> ISP Router (Bridged) --cable--> Wifi Router (LAN with external IP by bridged router) --cable--> Server NIC 2 ----------> Server NIC 1 --cable--> PC1 --cable--> Cisco Switch --cable--> PC2 --cable--> PrinterSo... If I set LAN of the Wifi Router in 192.168 (and Server NIC2 too) I could set Server NIC1 on 10.x.y.z network? I would put my PC1, PC2, Printer & Wifi network all in 10.x.y.z., making Server NIC2 the only device in 192.168. I would have to make port forwards on LAN Wifi Router then?? For incoming friends requests (VPN). I would need a different VPN port for each Hyper-V virtual machine?? And so each Hyper-V client MUST also be in the 192.168 network?? Because I want my Virtual Machines in the 10-network (file sharing, stuff like that). Or should I leave the 10-network out of it and am I just not getting it, again? Devvie
As I see things, giving the server direct access to the WAN and thus converting it in a gateway isn't possible due to physical limitations. I would go for the different external ports in port forwarding scheme. (Or maybe you can see something like X11-sesman, so they all get to the same terminal, they log in, and the terminal internally transfers them to the correct client)
Sigh... "easy" It's not impossible to put my Server directly to WAN, but I don't like it. So it must be done the complicated way... Preferable where all LAN clients (physical or virtual) can see each other.Anyone willing to guide me through it with teamviewer or something? If it's that easy... Show me where what and I'll probably figure this shit out. For now, I'm more clueless than I thought I was Devvie
She says using Team Viewer to help her configure the server and everythingWhat's your Time Zone devvie? I'm on GMT -4:00 I believe (Sometimes we go into GMT -3:00 Here)
Now almost 3 in the morning here (http://www.timezoneconverter.com/cgi-bin/zoneinfo?tz=Europe/Amsterdam)I can prepare stuff, no problem. I know my way around when needed But I want to do it the complicated way, meaning I won't expose my server to the WAN. Just too naked, not in a good way I might add (yes jheysen, I got your PM ).If "router configuration" is just a matter of setting up ports, it won't take more than 5 minutes... No fancy hardware, just SoHo stuff ;pI guess 2 server NICs should be wired to my SoHo Wifi Router? Keep them both on DHCP?Server Roles are already installed and I did not mess with them yet. What else can I prepare?I will now look in detail to previous posts...Thanks!!Devvie
