That's mostly your desktop ging too quickly... tell Windows to restart so it doen't quick boot, that should give you extra seconds. If that fails, disconnect the HDD so you are sure to enter bios upon booting. You can also keep DEL pressed on startup :p
As Soon As You Power On Your Computer, Keep The F8 Key Fully Depressed And See What Happens.Cheers.
Instead Of Removing The HDD, Try Removing The Keyboard First, And Then Power On The Computer Without It.Cheers.---
After updating to Windows 10 Pro [Anniversary Update], I needed to access BIOS on my Desktop. I have done this many times without any problem in Windows 7 Pro. Now, when I repeat-press DEL key on Start-up, nothing happens and the PC hangs.Has anybody faced this problem and solved it?
