ThanksBTW this is an external hard drive(In case required here is the pic of the drive here is the pic of the drive)- Last time I plugged in the drive it was working perfectly fine... today when i plugged in using three different cables its not working giving me the same beeping sound and flashing light... although i see my device manger displaying a driver as "intio combo default controller" when i plug in the hard drive- last used less than a week- yes it was working 100%- No i didn't install, format or partition the drive I will look at these cases two and see if i can find a solution out of it
