It seems that Softether was the cause of a BSOD hunting me for a long time. I always suspected a VPN application, now I know See: http://scforum.info/index.php/topic,8903.msg23656.html#msg23656Anyways, I removed the software with IObit Uninstaller and manually went to my registry and searched for more traces, which I found but could not remove!Also, removing the device "VPN Client Adapter - VPN123" fails. No error, but removing it will not work.Seems to be in par with the fact that I cannot remove the following registry key: HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Enum\ROOT\NET\0000\PropertiesIt is TOTALLY blocked. I tried all regular stuff (taking permission, resetting permissions, removing inheritance, ...) but NOTHING. I also tried to remove the key with RegASSASSIN (https://www.malwarebytes.org/regassassin/).So... Pretty please, developers... Is there an uninstall tool or *any* advise to remove this stubborn registry keys...?Duplicate in:HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\ROOT\NET\0000\PropertiesPlease help
Silly idea: Did you try to remove it from safe mode?
Quote from: jheysen on 08. March 2014., 00:56:29Silly idea: Did you try to remove it from safe mode?Great idea! No Will do once I need to reboot PC again. I'll be back in a few days ;p...
I know, not helpfull^^But the "locked" registry-key looks like normal windows behavior. For example, the Properties of my VirtualBox Adapter are locked too. But deinstalling the VPN-Adapter from the GUI-Tool removes the registry entry complety....so yes. You have a problem And I know that sounds like "Have You Tried Turning It Off And On Again?"(http://www.youtube.com/watch?v=nn2FB1P_Mn8) but have you tried to re-install the driver? I mean the function in the client tool.
More feedback from: http://www.*** Domain blocked by Admin ***/viewtopic.php?f=7&t=2782&p=5740#p5737 (qupfer)QuoteI know, not helpfull^^But the "locked" registry-key looks like normal windows behavior. For example, the Properties of my VirtualBox Adapter are locked too. But deinstalling the VPN-Adapter from the GUI-Tool removes the registry entry complety....so yes. You have a problem And I know that sounds like "Have You Tried Turning It Off And On Again?"(http://www.youtube.com/watch?v=nn2FB1P_Mn8) but have you tried to re-install the driver? I mean the function in the client tool.
"It seems that Softether was the cause of a BSOD hunting me for a long time. I always suspected a VPN application, now I know See: URL is scforum. dumb spam filter .info / index.php / topic,8903.msg23656.html#msg23656"...
...Rebooting to safe mode did not solve it either ...
Many fora block .info domains by default. Uphill battle I'm afraid ...
...Quote from: devnullius on 13. March 2014., 09:14:00Many fora block .info domains by default. Uphill battle I'm afraid ...I'll contact them directly... I hope that the story will end up better than with TipRadar.
Samker77 / Post subject: Re: Why is my domain blocked? / PostPosted: Mon Mar 17, 2014 5:49 pm "Since nobody reply after few days, I'll block your domain at SCforum also!"
