Thanks a lot for the useful info, I have a problem that i couldnt resolve; the wireless network in our company keeps disconnecting randomly ! once you are working and every thing is ok, then suddenly the network is disconnected and you have to "repair" the connection to get back online, any thoughts ?I tried configuring it to transmit on different channels but the problem is still there
Did you maybe have problem with "small" range or problems with transmitter - antenna...??
1. virus may be present in your network (clean all workstation and server without LAN connection)2. your wireless router may not be configured properly (reset it to default factory settings and try)3. your wireless router may be defective (try to change router and check)
georgecloner,Thank you for the info, it's a big help. How can we limit the wifi range, so that it will not go-out to the company building or to the neighbor.thanks
