  • Total Topics: 16078
  • Online Today: 3460
Author Topic: Office 2010 - Service Pack 2 (download)  (Read 13404 times)
zocker
« on: 27. February 2014., 12:30:32 »
Microsoft has launched Office 2010 SP2 a few months ago and here are the download links for SP2 for Office 2010.
Service Pack 2 (SP2) for Microsoft Office 2010 64-Bit Edition contains new updates which improve security, performance, and stability. Additionally, the SP is a roll-up of all previously released updates.
Filesize:
638MB (32 bit)
730MB (64 bit)
Download 32 bit: http://www.microsoft.com/en-us/download/details.aspx?id=39667
Download 64 bit: http://www.microsoft.com/en-us/download/details.aspx?id=39647
Re: Office 2010 - Service Pack 2 (download)
« Reply #1 on: 27. February 2014., 14:29:39 »
thx
« Reply #2 on: 27. February 2014., 18:53:09 »
Be ware of one thing regarding this Servicepack if you have not activating Office prior installation of the Servicepack 2.
"click the image to make it larger"
"Unable to activate after Service Pack 2 for Microsoft Office 2010 (KB2687455) is deployed"
Error message when you try to activate Office 2010: "An unspecified error has occurred. Your request cannot be processed at this time. (0x80070001)
Symptoms
When you try to activate Office 2010, you may receive the following error message:
An unspecified error has occurred. Your request cannot be processed at this time. Please try again later. (0x80070001)
Solution
Let me fix it myself
To resolve this issue, please do the following:
  1. On the Start menu, click Run, and then type regedit.
  2. In the Registry Editor, search for the following registry key:
HKEY_LOCAL_MACHINE\SYSTEM\CURRENTCONTROLSET\CONTROL\CLASS\{4D36E967-E325-11CE-BFC1-08002BE10318}
  3. Look for UpperFilters, which is type REG_MULTI_SZ.
  4. Double-click UpperFilters, and then under Value data, add PartMgr to the top of the list. Click OK.
  5. Restart the computer.
  6. Start any Office 2010 application and follow the prompts to activate.
You can also automate the process of adding this registry key, by running the following command on the run line:
reg add HKEY_LOCAL_MACHINE\SYSTEM\CURRENTCONTROLSET\CONTROL\CLASS\{4D36E967-E325-11CE-BFC1-08002BE10318} /v UPPERFILTERS /t REG_MULTI_SZ /d PartMgr /f
Source article: http://support.microsoft.com/kb/2400124/en-us
and: http://answers.microsoft.com/en-us/office/forum/office_2010-office_install/office-2010-activation-fails-after-sp2-with-error/3c7c7976-a662-42f0-84f2-d06d08496216?page=1
« Reply #3 on: 27. February 2014., 20:22:25 »
Filesize:
638MB (32 bit)
730MB (64 bit)
Thanks for reminder pal. :up:
Now, SP2 sticked, SP1 un-sticked!
« Reply #4 on: 28. February 2014., 09:48:10 »
Thanks for Pez, from here it found, how to fix it  :)
 :up:
