Author Topic: How to remove Watermark?  (Read 5890 times)
myphonecarduk
« on: 27. November 2016., 08:08:31 »
How to remove watermark form any image?????
Re: How to remove Watermark?
« Reply #1 on: 27. November 2016., 18:52:12 »
Kindly check this old Topic: http://scforum.info/index.php?topic=6219.msg18621#msg18621
I hope that it'll be helpful... also, don't forget to provide us feedback. ;)
cya later!
mitali
« Reply #2 on: 24. December 2016., 06:20:10 »
Open the photo with a watermark in Inpaint.Use the Marker tool to select a watermark area. Switch to the Marker tool on the toolbar and select the watermark area and then run the restoration process.
jasmeen123
« Reply #3 on: 29. November 2018., 06:18:11 »
hii,
Open the app that you used to create the watermarked photo.
Open the file that contains the watermarked photo.
Find the photo that contains the watermark.
Select the watermark text or image, then press Delete.
Right-click on the picture and select Save as Picture. Give the image a name, choose a file format and click Save.If you cannot select the watermark, it may be grouped with the picture. Choose the photo and then select Ungroup.
aradralami
    • لیزر موهای زائد
« Reply #4 on: 20. February 2019., 06:27:40 »
The best software application to remove watermark from an image is photo.wondershare.com/photo-eraser.html They call Wondershare Photo Eraser. It will help you remove image watermark in quick time with just few clicks of mouse. You need not to be a photo editing expert in order to use Fotophire Photo Eraser software.
Follow these steps:
Launch Fotophire Photo Eraser and select the watermarked image.
Select the watermark using fully customisable brush. You can pick the size and shape. Alternatively you can use the intuitive lasso tool that allows for precision selection.
Click Erase and the powerful algorithm will remove the unwanted watermark without impacting the background.
mikeduke990
« Reply #5 on: 15. October 2020., 16:22:07 »
Easily Remove Watermark from a Photo
Step 1: Open the photo with a watermark in Inpaint.
Step 2: Use the Marker tool to select a watermark area. Switch to the Marker tool on the toolbar and select the watermark area.
Step 3: Run the restoration process. Finally, run the restoration process by clicking the 'Erase' button.
OliverLucaz
« Reply #6 on: 24. November 2022., 08:49:41 »
There are number of ways to remove the watermark!
All you have to do is go to FOTOR's watermark remover and put your image here. Then tell them given requirements and you are done.
Another method is, You must have god skill so that you can simply remove it by your own.
You can also add blurry effect at that specific point. :)
