  • Total Topics: 16078
  • Online Today: 3827
Author Topic: Test Your FireWall Protection !!!  (Read 50188 times)
humbox
Re: Test your Firewall Protection with HackerWatch (by McAfee)
« Reply #10 on: 09. March 2009., 20:20:12 »
good and helpful tool thanks
duomaxwell22
  • If it is too good to be true, Don't believe it!
« Reply #11 on: 10. March 2009., 01:06:03 »
thanks for this!!!!
Bookmarked as favorite!
deadeye
« Reply #12 on: 11. March 2009., 23:52:13 »
If you are in doubt of your Firewall or just want to make sure your Firewall works like it is suppose to I recommend this site because it does a great job at checking every aspect of your Firewall.  Great way to check if you are truly protected.
V/r
deadeye
cozy_dave
« Reply #13 on: 14. March 2009., 02:36:36 »
great info... have to try...
dazkool
« Reply #14 on: 17. March 2009., 17:20:55 »
Heh, cool sight nightcleaner!
Good ol' WinXP firewall has stealth all the way!! :D
smith2100
Re: Test Your FireWall Protection !!!
« Reply #15 on: 18. April 2009., 16:26:04 »
thank you
demons75
« Reply #16 on: 24. April 2009., 11:14:28 »
On a computer firewall did not establish, I use that that DSL modem works in a mode router. Here but itself DSL modem to close from outside the Internet would cost on more carefully. Has checked up the modem by means of recommended Samker resource "PCFlank.com", it has appeared that from outside the Internet ports 23 and 80 though in modem options telnet and web services are closed outside are opened?!
Thanks Samker!
delta_777
« Reply #17 on: 27. April 2009., 10:55:15 »
I am using mcafee desktop firewall 8.0
symantec test reports
WARNING! Unauthorized persons can make connections to your computer. This means your computer and data are not safe from hackers. To learn more about why you are at risk click here.
Recommendation:
Install a personal firewall. If you already have a personal firewall, make sure it is correctly configured for optimum protection.
should I change my firewall software ?
« Reply #18 on: 28. April 2009., 08:17:19 »
Recommendation:
First try to change you Firewall Settings and repeat Test.
Please provide us new results?
Kdebian
« Reply #19 on: 02. May 2009., 12:48:37 »
Thanks
