Author Topic: SOLVED download windows xp driver SYMBIOS LSI LOGIC 53C875J PCI WIDE ULTRA SCSI!  (Read 9294 times)
Product information & picture, here: http://www.zdtronic.com/CONTROLLER-CARDS/SYMBIOS---LSI-LOGIC-CARDS/SYMBIOS---LSI-LOGIC-53C875J-SINGLE-CHANNEL-32BIT-PCI-WIDE-ULTRA-SCSI-HOST-BUS-ADAPTER.html
Copy Paste:
SYMBIOS / LSI LOGIC 53C875J SINGLE CHANNEL 32BIT PCI WIDE ULTRA SCSI HOST PCI BUS ADAPTER model 53C875J, manufactured by SYMBOIS.
Availability:    In Stock
Price:   $99.98 (or 50 cents at local dump shop ;p)
Description: LSI Logic Single Channel 32Bit PCI Wide Ultra SCSI Host Bus Adapter
Actual download in the reply...
Karma!
DOWNLOADED** DOCUMENT: "Adding Fireport Support to Windows XP.htm"
GIVES: 2 classic methods of installing the Diamond Fireport SCSI cards.*
BETTER: tip by devnullius: 5496_BusLogic_ba81c15.exe**
FROM: http://devid.drp.su/?l=en&down=updater&dev=PCI%5cVEN_1000%26DEV_008F%26SUBSYS_80001092%26REV_04
WHAT IT IS: GNU licensed Driver Detective alternative: DriverPack Solution (http://drp.su/)
FOR: PCI\VEN_1000&DEV_008F&SUBSYS_80001092&REV_04
   Diamond Multimedia Systems SCSI Host Adapter
   Microsoft XP
   Driver Date: 1999-11-14
   Driver version: 5.00.2183.1
Sadly enough, even DPS program couldn´t install the drivers fully automatically.
For Windows XP one should really try to get the fireport.sys file manually from a Windows 2000 Server installation.*
Luckily, I found this one as a classic download!
GOOGLE FOR: fireport 40
GIVES LINK: http://forums.driverguide.com/showthread.php?t=35490
LEADS TO: http://www.storagedrivers.com/companies/305.htm
DOWNLOAD CONTENT: scsi Fireport 40 PCI driver FIREPORT.exe Windows XP
DOWNLOAD LINK: http://www.storagedrivers.com/drivers/54/54850.htm
MIRROR DEVNULLIUS, including this README: https://www.box.com/s/74dgaxqpzrdboe2mjanc
IN THEORY, you can install fireport.inf & fireport.sys manually through device manager (unverified).
TO MAKE INSTALLATION EXTRA EASY: RUN 5496_BusLogic_ba81c15.exe (from drp.su) and when it fails, point it to this folder for this missing sys-file.
Continue setup and enjoy (took you hours googling too, huh? ;-)
Karma!
** downloaded from 7zip archive "FIREPORT.exe (with fireport.sys and fireport.inf for Windows XP). YOUR PASSWORD to EXTRACT == devnullius.7z" (https://www.box.com/s/74dgaxqpzrdboe2mjanc)
*ALSO SEE: http://forums.anandtech.com/showthread.php?t=697128
Copy Paste:
 01-09-2002, 12:19 AM      #3
MrBaseball
Senior Member
Im using a Fireport 40 in WinXp. I did a search on www.dejanews.com and found some instrictions on how to get it working.
My fireport 40 has been working great since I edited the scsi.inf file.
-Ben
Yes, it will work, but you have to edit the scsi.inf file. Here is the text of a message that explains how to do it. If you
would prefer, I can email you the scsi.inf file and fireport.sys file that are needed.
MarkS
chelseaman@hotmail.com
""From: "zzzzzzzzz">
Subject: Re: FirePort 40 NOT working
Date: Tuesday, May 22, 2001 2:13 AM
I got my Fireport 40 to work under Whistler beta 2. Haven't tested it
extensively, but it hasn't crashed me yet and all attached devices are
recognized.
I looked in \windows\inf\scsi.inf, which contains the driver
definitions for all SCSI cards -- there's a comment there indicating
that they're no longer going to ship the Fireport driver as a
supported "in-box" driver, even though it's known to work fine; the
only reason the .inf file mentions the driver at all is because they
want to LEAVE it installed if you upgrade from a system that already
had it. But they won't ever install it on a new system.
What I did, and what you can do *at your own risk*, is copy the
relevant sections from scsi.inf on a working Windows 2000 system, to
scsi.inf on your XP system. Then re-run "reinstall driver" for the
card, ignore the warning "you shouldn't do this because this driver
was not certified for Whistler" (note that before this hack, it never
even got this far), and when it prompts you for a missing
fireport.sys, supply the one in \winnt\system32\drivers\fireport.sys
on your Windows 2000 system.
Again, this worked fine for me, and likely will for you, but please
don't blame me if you try it and it screws up! The comment in the
.inf file from Microsoft leads me to believe that they think that
driver works fine, but the fact that they're not shipping the driver
any more would lead to the opposite conclusion, so who knows. This is
a pretty old card, and part of the reason it's in my test system is it
seemed flaky in my main system anyway.
Hope this helps some people... if you want more details on what I did,
all it was was to copy the values from Windows 2000's scsi.inf under
the sections:
[fireport_Inst]
[fireport_Inst.Services]
[fireport_Service_Inst]
to the corresponding sections of \windows\inf\scsi.inf on the Whistler
install.
;Diamond Manufacturer device list
[DIAMOND]
%fireport.DeviceDesc% = fireport_Inst, PCI\VEN_1000&DEV_008F
[fireport_Inst]
CopyFiles = @fireport.sys
AddService = fireport, %SPSVCINST_ASSOCSERVICE%, fireport_Service_Inst, Miniport_EventLog_Inst
ServiceType = %SERVICE_KERNEL_DRIVER%
StartType = %SERVICE_BOOT_START%
ErrorControl = %SERVICE_ERROR_NORMAL%
ServiceBinary = %12%\fireport.sys
LoadOrderGroup = SCSI Miniport
AddReg = pnpsafe_pci_addreg
Lories
It is only for the window xp, I never try to check it once, But not i need it because after updated window here are more options which are not good and now i am trying to resolve such options which they show me on these pages.
