  • Total Topics: 16219
  • Online Today: 6022
Author Topic: 3 Simple Tips You Should Know When Using Apple Mac OS X  (Read 12524 times)
« on: 19. August 2016., 21:51:50 »
How long have you used Mac OS X? Or you have recently switched from Windows to Mac? It doesn't matter. The matter is that did you ever know these useful Mac tips and tricks, which help your work simpler and quicker, such as switch between windows in Mac faster, control your web browser tabs, or even take screenshots.
Sometimes, your mouse and touchpad won't help your work faster enough. That's time you need to use shortcuts that will have the ability to speed up your work and do things that you never thought it exists. So, here are three simple Mac tips and tricks that will help you control your Mac computer easier.
Splitting Your Mac Screen Into Two Pieces
If you have used Microsoft Windows 7 before, then you might have known that it has the ability to split the entire screen into two pieces, which combined between two separate application windows. Technically, this feature will allow you to combine two different and active windows into one in your display. For example, you can combine two browsers into one to view two websites on your screen at a time. Each browser takes a half of your display.
Since Apple Mac OS X El Capitan, this split screen feature is available and worked like in Microsoft Windows 7. So if you want to show two different Mac windows on your entire display, follow the instructions below:
1. Firstly, choose the first window/application that you want to combine with the other. Then hit and hold the green expand icon on the top-left until it shrinks. After that, a half of your Mac screen will be highlighted and turned into blue.
2. Drag the above window to the left side on your Mac screen. Then choose the second window/application and drag it to the right side.
That's it! Your Mac display has split into two pieces, and each shows a different window. This is a great feature, which you can use to watch a YouTube video while chatting or reading an online newspaper, or checking your Facebook News Feed.
When you don't want to use this mode anymore, simply click on the green expand icon, and it will be restored back to the normal mode.
Take Screenshots In Mac Easier
If you have just switched to Mac OS X from another operating system like Windows or Linux, then you might feel strange with its features and shortcuts, such as copy & paste, or taking screenshots.
However, taking screenshots on your Mac computer is quite simple than you think. There are two simple shortcuts you can use to capture screenshots:
- Command + Shift + 3: This shortcut will help you capture a screenshot of the entire Mac screen and then save the screenshot file to the Mac desktop, by default.
- Command + Shift + 4: This shortcut will allow you to select a specific area of your screen to capture a screenshot. After hitting these keys at the same time, you can drag and resize the size of the area you want to capture.
Want to know more about capturing screenshots in Mac? Read more from this Print Screen Mac guide.
Control Your Web Browser Tabs Quicker
When you are working, you might not want to leave your fingers out of your keyboard. But how to switch between your browser tabs in Mac without using the mouse? No problem! You can control your web browser's tabs with these Mac shortcuts:
- Command + T: This shortcut will help you to open a new web browser tab.
- Command + W: This shortcut will help you to close the current web browser tab.
- Command + Shift + T: This shortcut is used to re-open the previous browser tabs you have recently closed.
- Command + Shift + {: To cycle your browser tab to the left.
- Command + Shift + }: To cycle your browser tab to the right.
Do you have any useful Mac tips & tricks want to add to this story?
Re: 3 Simple Tips You Should Know When Using Apple Mac OS X
« Reply #1 on: 20. August 2016., 21:34:27 »
These is good to know all Mac users' unfortunately I don't belong to that group.   :thumbsup:
 :up:
wudz
« Reply #2 on: 21. September 2016., 22:49:53 »
great to have seen this info
myphonecarduk
« Reply #3 on: 13. October 2016., 16:05:30 »
Great tips, Though I already know 90% of them. But thanks for your kindness and this awesome article man!  O0
Bharath7867
« Reply #4 on: 04. June 2017., 04:29:03 »
This is great to read all tips about the mac.
krishna88
« Reply #5 on: 06. November 2017., 12:48:15 »
Thanks @Samker for sharing some important tips about Apple Mac OS X, now it has got a new name as well called - MacOS High Sierra. also it has got some more new features updated it now has a new Apple File System (APFS) announced. It made it into iOS with the iOS 10.3 update.
If you are running Lion (version 10.7.5), Mountain Lion, Mavericks, Yosemite, or El Capitan, you can upgrade directly from one of those versions to Sierra.
The newest update to High Sierra (High Sierra 10.13.1) was released on 31 October 2017 and brings performance improvements, security enhancements and bug fixes, along with new emoji's as well.
Apple has also made its browser Safari more Speedier, smarter.
