  • Total Topics: 16528
  • Online today: 3053
Guests: 3035
Total: 3037
Author Topic: Mcafee virusscan enterprise, update to version 8.8 ??  (Read 17462 times)
Re: Mcafee virusscan enterprise, update to version 8.8 ??
« Reply #10 on: 04. August 2015., 14:54:48 »
Try making the window bigger. If that doesn't work, well, you'll have to wait until it has finished.
(probably it'll appear when VSE has calculated how much work it has to do)
Audiracecar90
« Reply #11 on: 04. August 2015., 17:37:22 »
Nope it will shows the status after full drive scan  :'( is anything i need to do?? Because when im using mcafee virusscan enterprise 8.7i it shows the status with GREEN color row
« Reply #12 on: 04. August 2015., 18:41:40 »
Are you talking about the green status bar that shows the progress of the scan?
If so then I can tell you that it is gone what i can see. I have checked up this on several Windows 7 computers its all the same.
I have also try to check this in some old Windows 2003 Server and that dose not either get any status bar.
Just so you know. I did this test for the status bar just under around 5 - 10 minutes. So if it appear later on the scanning I cant tell. But when I stopped the scanning it appeared under a few sec befor the windows closed.
Regarding the Areo look I cant tell way you get the old look but some thing to check is if you nave some problem with the Areo. Try to check if their is some new Video card devise driver.
I have non problem with the Areo at my Windows 7 computers.
Do also note that VSE 8.8 patch 5 and earlier is not supported and working in in the new Windows 10. The mini requirement is patch 6 that is schedule in 26 August 2015.
http://scforum.info/index.php/topic,10158.0.html
Audiracecar90
« Reply #13 on: 05. August 2015., 04:12:39 »
Ok so the problem is same Np ;)
Audiracecar90
« Reply #14 on: 06. August 2015., 04:52:02 »
hai jheysen today morning only my PC updated to Windows 10 and i want to know which antivirus should i use now???????
« Reply #15 on: 06. August 2015., 04:53:32 »
I'm using Windows Defender..
But we have a topic were we discuss the pros and cons of different AV solutions, maybe that will help you ;)
« Reply #16 on: 06. August 2015., 06:55:44 »
McAfee VirusScan Enterprise 8.8 is not currently supported in Windows 10! Will be supported with Patch 6 in Windows 10.
See more about this!
Audiracecar90
« Reply #17 on: 06. August 2015., 08:23:59 »
Ok thankyou J and P ;)
Edomontero
« Reply #18 on: 21. October 2016., 16:56:56 »
For those who have problems with the latest update of Windows 10 (Anniversary Update), you must install the latest version of McAfee VSE 8.8 Patch 8. Can be found at: http://scforum.info/index.php?topic=11869.0
herwin94
« Reply #19 on: 03. December 2016., 05:07:28 »
there are already version 8.8 patch 8 sir.. with improvement and bug fixes
