  • Total Topics: 10980
  • Online Today: 4595
Author Topic: Need to recover access database with superior solution to fix access database er  (Read 4449 times)
kayones867
I have a task regarding access database. I and my organization is using access database to maintain my access files in well mannered way. But due to varied reasons access file showing error message
Error 3112: Your access database got corrupted will not be able to show the database.
Due to this error message I will not be able to access my access database. I don't have any idea how to recover access database or how to fix access database errors without affecting my original database? Is there any relevant solution to repair access database?
Can you try to open it in another computer? The error says the file is corrupted
SSD ?
« Reply #2 on: 17. August 2015., 03:24:12 »
What Caused The Corruption ?
A - Was It Stored In An SSD ?
B - Did The Software Crash ?
C - Did The Computer Have An Abnormal Restart, Shutdown Or Power Failure ?
Just Asking.
http://data-base-recovery.blogspot.com/2012/02/how-to-fix-error-3112-in-access.html
Cheers.
mendezfremar
As he says that in Microsoft access database a option is available Compact & Repair utility to repair access database but this task will be time consuming for huge amount of database.
The error 3112: Microsoft Jet engine database will show this error message with DAO error. These errors are common for access users and got inaccessible database. In such situation to recover access database you can use advance Access File Recovery tool and this will also fix access database errors. Otherwise you can check the following Microsoft article to repair access database
https://www.daniweb.com/web-development/databases/threads/497944/opening-access-file
jeremyscastongs
Flawlessly repairs corrupt ACCDB and MDB database that is damaged. It addresses several issues in all scenarios like software conflicts, hardware failures and inconsistent database design. It also supports MS Access 2000, 2002, 2003, 2007, 2010 and 2013. Go through: http://www.recoverydeletedfiles.com/access-file-recovery-tool.html
manual2100
i had the same problem. I tried several free programs. Only one did the job (i dont remember the name). You should try some repair programs and see what happens. Try the free ones first and if nothing happens you can try some freeware. These programs inform first if they can fix the database. Then you can buy them if you like...
Suko
I think that service the "db diagnostics" can help. What do you say about the db diagnostics?
