  • Total Topics: 16500
  • Online today: 2080
Guests: 2077
Total: 2079
Author Topic: ESF Database Convert 5.6.24  (Read 2942 times)
« on: 22. September 2007., 22:47:37 »
 License:   Demo , 129 $ to buy
 Size / OS:   2.65 MB, Windows 2K/XP/2003/Vista
 Last Updated:   September 21st, 2007, 06:34 GMT
Database Convert description
An application that converts between various database formats
Database Convert is a program that allows you to convert between different database formats. It can directly connect to MySQL, SQL Server, PostgreSQL, Oracle, Access, Excel, Paradox, Lotus, dBase, Text and other formats, and convert between these formats (SQL Server to MySQL, MySQL to Access etc.).
ESF Database Convert offers a simple step-by-step wizard, that allows you to connect to the source database, select the tables, and then convert and copy them to the destination. You can choose to include all data or just copy the structure of the database.
The program provides all the required conversion options, taking into account the peculiarities of both input and output database formats. You can convert files exactly the way you want it.
ESF Database Convert  includes the support of table Primary Keys, Indexes and Auto-ID. It also maps table and field names in
converting. The tool comes with the batch conversion mode that can enhance productivity by speeding up the entire conversion process. ESF Database Convert stands out for being the most intuitive, comprehensive and effective tool in its category.
Here are some key features of "Database Convert":
· The ESF Database Convert software is wizard-like; it's so easy and quickly, everyone can use it. You convert one database to the other just only 3 steps
· Supports various database formats. It can interchangeably convert MySQL, SQL Server, PostgreSQL, Oracle, Access, Excel, dBase,Paradox, Text.
· Supports table Primary Keys, Indexes, and Autoincrement(Auto-ID)
· Supports Batch Insert/Update records to increase converssion speed! It lets ESF Database Convert run faster than other program
· You can interchangeably convert MySQL to Access, Access to Oracle, Oracle to SQL Server, SQL Server to MySQL, ... and etc in one product
· Via ODBC DSN, you can convert datas from any type database
· Map table & field name in converting
· You can use SQL statement to filter datas to be converting
· Supports all the UNICODE characterset (UTF8, LATIN, CP1250, ASCII and so on)
Requirements:
· Microsoft MDAC 2.6
Limitations:
· Converts only 10 records for each database table
Download: http://www.easyfrom.net/download/dbcv.exe
