  • Total Members: 14187
  • Latest: focel
  • Total Topics: 16420
  • Online Today: 6295
Author Topic: Web Calendar Pad 2007.8.1  (Read 2915 times)
« on: 22. September 2007., 22:55:00 »
Web Calendar Pad description
Make HTML calendars that visitors can view, print, download and subscribe
The Web Calendar Pad is a program that you can use to create illustrated monthly calendars, that can look like wall calendars and be published automatically to your website, a file, or be printed.
Perfect for businesses, schools, churches, clubs, organizations and personal calendars.
Web Calendar Pad helps you create an HTML illustrated calendar.
Web Calendar Pad makes it easy for some one with zero knowledge of HTML to create, publish, and update online event calendars,
in mere minutes. No need to battle html code ever again  , you can choose the look of your calendar from a large list of defined
styles, or easily create your own custom look that can include photos, backgrounds, and custom fonts.
Here are some key features of "Web Calendar Pad":
· Create Web Calendars that can include photos, backgrouns, and custom fonts
· Easy to use and quick to publish
· Lets you keep data in a separate calendar for each subject, but selectivly merge when publishing
· Supports the FTP protocol of file transfer, that makes it easy to publish your calendars on the internet
· Supports Macros, that let you use short-cut key words and then replace them with full text allowing you to reduce the amount of typing
· Built in wizard, lets you define the look of your calendar, or choose from predefined theme
· Lets you add custom headers and footers to you html calendar
Requirements:
· 15+ megabytes of disk space
Limitations:
· 30 days trial
What's New in This Release:
· A final link to the calendar is shown to the user
· Code to embed the calendar in frame is generated and show to user
· The appearance of an event can be selected from a drop down list
· Style Editor has now been updated, crush problem fixed..
Download: http://www.html-calendar.com/download/calendarpad.exe
