  • Total Topics: 16978
  • Online today: 137655
Guests: 134574
Total: 134576
Author Topic: Bored about the new Windows look in 8, 8.1 and 10  (Read 20452 times)
0 Members and 26 Guests are viewing this topic.
« on: 31. August 2015., 14:16:49 »
Are you bored about the new Windows look in 8, 8.1 and 10.
Do you  want back the Aero Glass from the Windows 7.
Then can this be a solution:
http://www.glass8.eu/
The Windows Glass for 8.1 have now support for Windows 10 up to build 10240 and experimentaly for build 10525.
• Apply glass look to windows borders
• Blur the content behind the borders to improve UI experience
• Change amount of transparency in Control panels directly
• Change inactive windows borders color
• Skin windows borders (add glow, shadows etc.) without changing Windows theme
• Fully native including MSStyle themes and DWM API compatibility
• Low resources usage
Glass look
Your windows will be rendered with transparent borders. This look allows you to see what is behind the border. The key element is the blurring of content behind the glass borders to prevent it from being too clear and disturbing. The result is very smart window border!
Fully native
The utility is completely integrated into Desktop Window Manager without breaking any system protection or modifying system files. All rendering is done via native Direct3D device. Any colorization settings adjusted in Windows Control Panels are respected. Use color intensity slider to adjust the amount of the transparency.
 No custom skinning engine used. Due to the native nature of this utility your Windows theme is composited together with the glass effect. All features controlled through DWM API (e.g. DwmEnableBlurBehindWindow or DwmExtendFrameIntoClientArea) are supported including the taskbar or custom Start menu blur effect.
Low resources usage!
This library tries to utilize all DWM resources as much as possible to minimize RAM and VRAM usage. No redudant objects are created, no background service is running (Win8 only; Win8.1+ version needs light-weight background process to correctly load user's settings). The result is light-weight library which behaves exactly in the same way as Aero Glass in Windows 7 did. No performance degradation!
Theme your windows!
You can change the look of your windows borders completely without touching your Windows theme or using unsigned theme. This allows you to bring back several effects such as window shadow, caption glow effect, rounded borders or simply change the appearence of caption buttons. You just modify single bitmap in your favourite image editor and everything will look as you want!
•Is it possible to enable blur on the taskbar (Alt-Tab window, any other window etc.) ?
Yes, this is possible. Remember that DWM is the rendering engine only and Aero Glass is the extension for it, so it will blur any window which is marked to be blurred. However, the taskbar is not a part of Desktop Window Manager but it belongs to Windows Explorer shell. For this reason, Aero Glass will not set blur flag on it and you must ensure it on your own by calling DWM API function DwmEnableBlurBehindWindow. Blur effect will also apply tint of glass color.
 Windows 8.x Desktop Window Manager contains new feature called accent. It is a kind of effect which makes whole window fully transparent with tint of glass color. This effect is enabled on the taskbar by default. If you enable blur on the taskbar but don't disable accent effect (using SetWindowCompositionAttribute API function), you may notice that it will be much more colorized, because the color of both effects will be simply added together.
 If you are not familiar with DWM programming API, you can use any of the existing tools that have option to call the DwmEnableBlurBehindWindow function, such as StartIsBack or ClassicShell. You can also abuse a internal Windows Explorer feature - if your theme file name is equal to aerolite.msstyles, it enables blur on the taskbar, disables the accent effect and vice versa. For very advanced users, there is a command line tool which allows you to alter any window's composition attributes.
Also remember that taskbar appearance is influenced by used theme where texture used for the taskbar is different from the atlas texture used for windows frames rendering.
• Can anyone install this software on his computer?
This library is intended for advanced users only. If you are a beginner and you do not have at least basic system knowledge of Windows (such as registry editing etc.) you should not install this software. Also, this guide counts that you are advanced user and explains several things in technical language.
http://www.glass8.eu/guide.html#themes
Re: how to get Aero Glass for Windows 10
« Reply #1 on: 31. August 2015., 19:30:15 »
Excellent, thanks P. :thumbsup:
P.S.
It looks that there is some problem with inserted images. ???
temporary
Re: Bored about the new Windows look in 8, 8.1 and 10
« Reply #2 on: 28. May 2022., 17:36:11 »
Bored with the new look in Windows 8 and 10? Are you a lover of classic styled windows applications? Does your eyes just not like all these round corners and other unneeded animations? If yes, then it's time to get a Classic Shell. We are giving you the perfect knowledge through this https://provista-plumbers-perth.tumblr.com/ website.
AliceBjelke
« Reply #3 on: 28. June 2022., 09:13:11 »
It would be difficult for me to find in excess of a modest bunch of individuals I'd prefer have dealing with a business office 365 e1 I was part proprietor of. I likewise think the ongoing game plan is a decent one.
JessicaSverj
« Reply #4 on: 28. June 2022., 12:57:09 »
Gear box: Also known as transmission, gear box can be arranged into manual and programmed models. Today a large portion of the vehicles have programmed gear boxes which https://www.autoplusdubai.net/ica-smart-services are very helpful contrasted with the customary manual stuff box.
AliceBjelke
« Reply #5 on: 15. July 2022., 12:33:45 »
Is the oil from a trustworthy source? The oil probably won't have been 100 percent naturally developed and from a trustworthy source. Just oil of this nature will hold the https://weedrepublic.com/ right cannabinoids and not have any extra synthetic substances.
Olgahelps
« Reply #6 on: 27. September 2022., 13:01:51 »
Trade margin, also called gross profit or contribution margin, is a particularly useful sweetcrumbsonline tool. It helps merchants easily identify the products and policies that are moving the company toward or away from profitability.
enerEr
« Reply #7 on: 12. October 2022., 08:22:31 »
Boredom is a symptom of lack of information and lack of experience. That's why we all need to learn something new. This article will introduce you to a new Windows look in Windows 8, 8.1 and 10 (and especially in the latest two versions) https://www.huffingtonpost.ca/gloria-kopp/essay-writing-payments_b_14793970.html. The presented material focuses on the problem solving aspect of my work.
Dberdes
« Reply #8 on: 19. November 2022., 06:24:03 »
Since the release of Windows 8 and its successor 8.1 , many users have been annoyed with the new user interface, especially in tablets where it has been removed from the Start menu. The new flat design mode seems to be a little more "boring" than expected by a lot of users. This new look has even made its way into Microsoft's mobile OS, Windows Phone . With that said, many are experiencing some negative reaction towards this new Windows look, because they're not willing to change their habits in order to adapt to it and that may lead up having problems with some https://pychedelichigh.com/buy-psilocybin-capsules applications or games not working properly due to this UI update.
Adam Dever
« Reply #9 on: 15. May 2023., 08:12:29 »
Are you in search of an eassy maker? AI-powered essay makers can be a helpful starting point, but they shouldn't replace the skills of a human writer. While these tools can generate content based on provided keywords, they might produce generic and impersonal essays. Collaborating with a skilled writer who can incorporate your specific requirements and provide original insights will result in a more engaging and tailored essay.
