  • Total Topics: 17050
  • Online today: 10764
Guests: 10738
Total: 10740
Author Topic: Problem installing Mcafee virus scan enterprise 8 in windows 10  (Read 16797 times)
Audiracecar90
Hai guys today i tried installing mcafee virus scan enterprise in windows 10 it shows error like this
Audiracecar90
Re: Problem installing Mcafee virus scan enterprise 8 in windows 10
« Reply #1 on: 01. September 2015., 04:59:03 »
Is there anything else needed to install this on win 10???
« Reply #2 on: 02. September 2015., 00:15:50 »
Yup, VSE 8.8 P4 is incompatible with Win10, you'll need a repost full package with patch 6 in order to install it in Win 10.
Audiracecar90
« Reply #3 on: 02. September 2015., 03:02:57 »
Ok thanks J how should i got this?
Audiracecar90
« Reply #4 on: 02. September 2015., 09:17:07 »
Ok guys finally i got this on win 10. But i face this  :'( :'( :'(
In this when i scan my pendrive it doesnot show progress of completion but it shows only after scan complete in fig3
« Reply #5 on: 02. September 2015., 14:53:23 »
@ Audiracecar90
It's as thay say a feature:o ;)
It have been like this on VSE 8.8 from Win 7 and forward what I know. It seems not to have been fixed yet probably it would not bee before some one pointed it out to McAfee and it would probably not be a prioritized bug to fix because it is more and less cosmetic.
The old progress bar was not in Win XP reliable because it was calculated from the first files in the scan. To make a reliable calculation you need to scan thru the whole scan and look at the file type and numbers of files. That take time and make just the whole scan to take longer time and disk i/o from the scan.
So my suggestion look at the info about what file is scanned. The you can see the progress thrue the folders on the drive and how long the progress have gone. It works fine for me after the first faze of the scan have completed with the started programs, startup files and memory scan.
But even I want to see a working progress bar but not in cost of the scan time that I value more to have a short time.
Audiracecar90
« Reply #6 on: 02. September 2015., 15:02:01 »
Ok thanks Pez then in mcafee 8.8 all of them facing the same issue am i right? As like working progress bar??
« Reply #7 on: 02. September 2015., 15:21:17 »
Yes what I know atleest.
I don't remember if it was so with VSE 8.8 on XP. But in Win 7 it allready was this feature. ;)
Audiracecar90
« Reply #8 on: 02. September 2015., 15:24:06 »
Ok thanks bro  ;) ;)
mmgpotax
« Reply #9 on: 04. September 2015., 23:53:41 »
It would be better a clean install, try this disabled Windows Defender to do it and then just activate the installation in administrator mode.
 O0 :up:
