  • Total Topics: 17039
  • Online today: 20283
Guests: 20266
Total: 20267
Author Topic: SCREEN WITH SHADOWS.  (Read 10406 times)
A41202813GMAIL
  • XPOCALYPSE FOREVER !
« on: 09. September 2015., 08:16:51 »
Hello,
Over Time, My Screen Developed Small Shadows On The Right When The Font Is Really Big And Dark Against A Light Background.
The Problem Got Worse Now, More Fonts Developed Shadows.
I Reinstalled The Monitor And Video Drivers From The Manufacturers Sites.
I Shut Down The PC Several Times.
I Restarted It Even More Times.
No Success.
By No Means It Is Impossible To Work, But It Is Annoying.
If The Problem Worsens, I Might Be Forced To Replace And / Or Change The Monitor And / Or Video Card.
Any Such Experience Out There ?
Thank You.
Re: SCREEN WITH SHADOWS.
« Reply #1 on: 09. September 2015., 14:26:14 »
I would begin by trying another monitor.
Did you try with Cleartype configuration wizard?
A41202813GMAIL
« Reply #2 on: 09. September 2015., 20:28:48 »
I Changed Some Settings Including The ClearType, And Put Everything Back As It Was - I Think.
It Worked, Even The Small Shadows Have Disappeared - I Hope.
It Looks Brand New, Now.
Thank You Very Much.
A41202813GMAIL
« Reply #3 on: 09. September 2015., 23:48:52 »
Wishful Thinking - I Spoke Too Soon.
Recurring Problem ?
The Ghosts Came Back After I Powered Off The Monitor For A While.
I Am Not Going To Replace Any Hardware, For Now.
( Update )
I Tighten The VGA Cable End On The Monitor, And Everything Looks OK, Again.
Lets See If It Sticks, This Time Around.
Thank You.
A41202813GMAIL
LINKEDIN.
« Reply #4 on: 15. September 2015., 02:14:33 »
Thanks To Our LINKEDIN Connection, This Topic Is Now On My Most Recent Updates Page.
Thank You, Team SCF.
LINKEDIN.
manual2100
« Reply #5 on: 12. September 2016., 11:45:26 »
If the cable thing doesnt work it might be the monitor. You can only be sure if you install a new monitor (borrow one from a friend of yours). If it is the monitor there are many causes for this.. ( i do not know if it better to service it or buy another one). If it is an LCD monitor keep in mind that they have a life of about 3 years of use.
A41202813GMAIL
« Reply #6 on: 12. September 2016., 12:17:33 »
The Monitor Was Always Usable Even With The Problem.
I Swapped The Extremities Of The VGA Cable And The Problem Disappeared, Months Ago - The Extremity Now On The Computer VGA Port Apparently Has Some Bad Connection But No Problems Since The Swap.
Repairing A Cheap Monitor Costs About The Same As Buying A New One - Easy Decision.
This Is A 3 Years Old LED SAMSUNG SyncMaster S22B150 - It Can Not Be Sold As Brand New Because It Has An Almost Invisible Small **Square** 1mm White Ghost On The Bottom Right - I Wish All My Past Monitors Were This Good.
Thank You.
bigfootangel
« Reply #7 on: 04. October 2016., 02:12:51 »
It can be problem of computer graphics card or screen resolution you have set, it is not appropriate resolution for that monitor ...
A41202813GMAIL
« Reply #8 on: 04. October 2016., 02:26:37 »
Hard Pressed To Post 10 **Useful** Comments, And Can Not Even Be Bothered To Read The Last Posts On Any Thread Before Posting ?
