  • Total Topics: 17057
  • Online today: 43641
Guests: 43643
Total: 43646
Author Topic: zip file error in xp  (Read 7232 times)
patrickkeitel
« on: 23. October 2015., 20:44:10 »
please help if you can,  i uploaded some zipped files to two diferent
locations(my briefcase at yahoo and mydocsonline)using winzip and
downloaded to check if the upload was successful and i get these error
messages, every one of the 12 files had similar error messages but i'll
copy two
 here for you to see..
Extracting to "C:\Documents and Settings\Administrator\Local
Settings\Temp\"
Use Path: no   Overlay Files: yes
Extracting SanTel unlocker.exe
Error:  invalid compressed data to inflate
Settings\Temp\"
Extracting psmplay.exe
bad CRC 619a3819  (should be 4286d7a4)
Warning: the size of the extracted file (307298) does not match the
uncompressed size (307200) recorded in the zip file
i have since used two more zip file programs(handy bits zip & go) and
(coffeezip20)
and get the following error message when i have downloaded the zip
not a valid win32 application
incidently i don't get any errors when i upload and dowmload teh same same
zip file using ftp terrapin to my ntl webspace..
any help please
Re: zip file error in xp
« Reply #1 on: 24. October 2015., 03:23:04 »
Looks like the problem lies with the upload, did you try to extract the files from a just created zip file, before you upload it?
A41202813GMAIL
  • XPOCALYPSE FOREVER !
ZIP FILES.
« Reply #2 on: 24. October 2015., 06:59:31 »
( Related Or Maybe Not )
WINZIP Is My Favorite Program For Creating ZIP Files.
How To Avoid Problems I Had With WINZIP:
A - Always Use Stable Program Versions - I Once Used A Beta Downloaded Version And It Generated Corrupted Files,
B - Always Use Legacy Compression - It Will Take More Space But It Will Be Backwards Compatible With Older Software.
Cheers.
volkerschwefel
« Reply #3 on: 30. October 2015., 01:04:36 »
Given below is a step by step method to repair ZIP files using inbuilt utility available in a WinRAR application or another variants I would suggest you only in case the guide can't help you, you may see it below, last one is the most powerful, but not for all cases
http://itknowledgeexchange.techtarget.com/itanswers/how-to-repair-zip-files-after-zip-archive-corrupt-or-damaged/
http://www.reddit.com/r/software/comments/2iqnap/zip_file_corrupt/
https://www.openfiletool.com/zipopen.html ZIP Open File Tool
Given below is a step by step method to repair ZIP files using inbuilt utility available in a WinRAR application:
•   Start WinRAR application.
•   Go to file menu and click open.
•   Through the find archive window, select the corrupted ZIP file available in your local machine.
•   Click to open.
•   Initialize repair by pressing ALT + R.  A message saying, Repairingfile_name.zip will appear.
•   Once the repair is done, it will ask you to save the repaired ZIP file. Browse a specific location for saving the selected file.
•   Enable Treat the corrupt archive as ZIP box and click OK and click close.
