  • Total Topics: 16999
  • Online today: 23577
Guests: 20823
Total: 20823
Author Topic: Windows PAE Patch + patch tool (!!) for Windows 7/8/8.1 & 10! Give x86 more RAM  (Read 38647 times)
We all have been there... x86 Windows and you want to add and use more than 3 / 3.5 or 4 GB RAM. Should work, right? Because x86 Windows does NOT have a RAM limit, contrary to what people want you to believe... Really, it's a hardware limitation fanatically enforced by Microsoft.
Solution to address more than 3, 3.5 or 4 GB RAM (values vary) have been available for a long time. It's called the PAE Patch by http://wj32.org/.
Implementing the patch always has been a pain in the ass with lots of details that can go wrong (at least, I'm always stumbling with it like a first class amateur ;p).
Today I upgraded a machine from Windows XP to Vista, 7, 8, 8.1 and finally Windows 10. In the process I lost the PAE Patch I had working on Windows 8.1. I started googling, but sadly WJ32 did not release a Windows 10 patch, yet.
I tried the manual approach but was failing once more. Sigh.
LUCKILY, this time around I found a patch that will do all the manual labour for me!
I found it here: http://wj32.org/wp/2013/10/25/pae-patch-updated-for-windows-8-1/#comment-12806
Gives download link: https://mega.nz/#!3tASjKpS!MyJfOB3v2lOTFx1nXHtKors2fpdHLJD_Ik_DfPidA3Q
MIRROR: https://app.box.com/s/hyy3wr9s9yel8hrvrb31
And after testing it really worked XD
Enjoy your x86 system!!
PS: there are also (YouTube) solutions suggesting you simple enable the extra RAM with msconfig startup options. This does NOT work. Yes, Windows sees the RAM but CANNOT use it! The PAE patch is really the only way to do it.
Peace!
Yours truly,
Solved! Is there a PAE 32-bit patch update for Windows 10
Re: how to use more RAM on x86 Windows
« Reply #1 on: 17. November 2015., 15:29:20 »
As usual, you have a really good tips even for advanced SCF members.
Thanks D. :up:
:) you're welcome, my friends
Augusto
O arquivo que você está tentando baixar não está mais disponível.
Isto pode ser devido às seguintes razões:
O arquivo foi removido por causa de uma violação Termos de Serviços / Política de Uso Aceitável.
URL inválida - o link que você está tentando acessar não existe
O arquivo foi apagado pelo usuário.
Augusto
(The file is unavailable)
jyukyu
This will be extremely beneficial for my project.
Basket Random
natasha
Thanks for sharing this article. I am glad to see this amazing post. waffle
Aaron Ramsdale
Thanks for sharing this helpful information. I appreciate it.        fall guys wordle unlimited
Abby Hao
Thank you all for sharing. Let's learn from each other. Thank you! https://www.pcbpret.com
