SCF Partnership Ads
  • Total Topics: 17083
  • Online today: 20966
Guests: 20965
Total: 20966
Author Topic: Recover a project file  (Read 10093 times)
nietoramos
« on: 19. January 2016., 18:03:49 »
I was saving a project on Visual Studio 2008 Pro when my computer rebooted.
Now when I open a solution, I get the message "Unable to read the project file 'XXXXX.csproj'.".
I checked this file, it contains only nulled chars (instead of all the config of the project).
Is there a way to recover or regenerate this file?
Thanks for your help.
Hi,
Do you have installed SP1 for VS2008 ??
As I know, this issues is resolved in mentioned Service Pack: https://support.microsoft.com/en-us/kb/950263
cya later,
simon_vanbeek
Re: Recover a project file
« Reply #2 on: 28. January 2016., 16:10:16 »
I had this situation. Try to do the following.
1. Create a new similar project
2. Copy the content of the *.csproj (or vbproj, etc.)
3. Remove all the "Compile Include" references.
Basically this:
    <Compile Include="Form1.cs">
      <SubType>Form</SubType>
    </Compile>
    <Compile Include="Form1.Designer.cs">
      <DependentUpon>Form1.cs</DependentUpon>
    </Compile>
4. Launch your project, it should starts with none of your forms, class...
5. Add all your existing items in your project...
In the extreme case, if this advice does not help, then try to use the service of online repair Microsoft Project. Maybe it will help. https://onlinefilerepair.com/en/project-repair-online.html
Hope that helps!)
nietoramos
« Reply #4 on: 31. January 2016., 16:57:28 »
thanks. solved)
