banner
banner
  • Total Topics: 13022
  • Online Today: 1265
banner
Author Topic: [ANN][BitSend][BSD][MAIN THREAD][Bittrex|Safecex|Cryptopia][New Update 1.0.0.1]  (Read 3774 times)
vindyne8
  • SCF Hero Member
    • Vindyne Group
French thread | Russian thread | Spain thread |
BSD - Bitsend Core 1.0.0.1
http://www.bitsend.info Bitcointalk https://bitcointalk.org/index.php?topic=1370307
Copyright (c) 2009-2015 Bitcoin Core Developers Copyright (c) 2014-2015 Dash Core Developers Copyright (c) 2014 Doge Core Developers Copyright (c) 2013 Dr Kimoto Chan Copyright (c) 2014-2015 LIMX Core Developers Copyright (c) 2016 BitSend Core Developers
Release 14.02.2016
The Version 1.0.0.1 adds new functions.
    BitSend Diffbreak - This function protects the chain against huge miners. After 6 hours every CPU-Miner is able to create new blocks.
    KGW3 - The new KGW setup is now smarter and has a new hard retarget after 60 Blocks (Backup)
    The new Version supports 4 MB blocks
    We increased the TX fee's for more security (Blockspaming)
Rebrand from LimecoinX to BitSend
    New GFX and Name
    Limecoinx ->BitSend
    LIMX ->BSD
    new protocol 70077
What is BitSend? What is the different?
BitSend isn't a short term project. It is private digital currency for every generation. The POW and POS period goes 100 Years. This is for a fair distribution.
BitSend doesn't have a blockhalving or ponz scheme. Also in 10 year or 20 year can you can mine BSD like today. You can mine BSD without mining equipment. You need only
5000 BSD and a server with static IP address.
Why a 6 min Chain?
BitSend does not generate thousands of empty blocks daily. This doesn't make a coin better or secure. Only 240 blocks will generate per day.
For a fast payment you can use "InstantX". This transaction need only one conformation. The next advantage is a fast client synchronization and less harddisk space.
Why 525 Mio Coins?
Yes 525 Mio BSD is much. But the Distribution is very slow. We generate per Year ~4.35 Mio BSD. In 4 years also 17,4 Mio BSD. Litecoin generate today (after first blockhalving) in 4 years 21 Mio LTC.
The advantage is the fair Distribution for the next Generations.
Masternode Network
Masternodes are full nodes, just like in the Bitcoin network, except they must provide a level of service to the network and have a bond of collateral to participate. Collateral is
never forfeit and is safe while the Masternode is operating. This allows investors to provide a service to the network, earn interest on their investment and reduce the volatility of the
currency.
Due to the fact that the Masternode rewards program is a fixed percentage and the Masternode network nodes are fluctuating, expected Masternode rewards will vary according
to the current total count of active Masternodes.
Darksend
DarkSend is the name of the decentralized mixing implementation that obfuscates and provides a greater degree of privacy/anonymity to the transactions of the BitSend network.
Obfuscation is achieved by using network nodes in order to break up and reroute the flow of money in a way that is hard to track down. Further obfuscation takes place by using similarly sized pools of money which makes it difficult to pin-down identical amounts to a certain transaction especially when multiple transactions are occurring simultaneously, all with the same amount of money. Multiple rounds of mixing are employed so that tracking payments becomes exceedingly difficult as the number of mixing rounds increases.
This process requires more time than normal transparent transactions as time is needed to accommodate the pooling of multiple transactions. To solve this issue, the ability to pre-mix coins has been implemented so that one can use "anonymized" coins right away.
InstantX
InstantX is a service that allows for near-instant transactions. Through this system, inputs can be locked to only specific transactions and verified by consensus of the Masternode network. Conflicting transactions and blocks are rejected. If a consensus cannot be reached, validation of the transaction occurs through standard block confirmation. InstantX purportedly solves the double-spending problem without the longer confirmation times of other cryptocurriencies such as Bitcoin.[7]
I've same task for BitSend.
Dev Task
Technical
- Android Wallet
- IOS Wallet
- TOR Gateway in wallet.
- Blockchain pruning
- Darksend development ( improvement)
- a interface for control of objects (Rent of Objects)
Marketing
- A Simple Forum ( I pay 500 BSD in the month (first year))
- BTC38 Listing
- Bter Listing
- Poloniex Listing
Latest version: v1.0.0.1 (15-02-2016)
Source: https://github.com/LIMXTEC/LIMX
https://sourceforge.net/projects/bitsend/
Apps: in work
Algorithm: X11
Transaction confirmations: 6
Total coins: 525M
Block reward: 50 BSD
Block time: 360 seconds
Premine: 1,34M (0.3% of total coins)
Used: 24%
0.42 M premined coins + 0.9 M already mined LIM coins.
This Coin are lost or sell. From first Dev "Member Iparn"
More information:
https://www.bitsend.info
https://community.gulden.comhttps://twitter.com/Bit_send
_____________________
Bittrex
[url=https://www.southxchange.com/Market/Book/BSD/BTC]Southxchange  |
  Cryptopia
Cryptopia  |  Yobit New
Coingather
Cointopay | BTC POOL
MPOS Aika
Cryptopools New BSD
Multipool Zpool
HashHungry New !!
rpcuser=username
rpcpassword=password
rpcport=8800
rpcallowip=127.0.0.1
server=1
daemon=1
listen=1
addnode=107.170.2.241:8886
addnode=45.58.51.22:8886
addnode=104.207.131.249:8886
addnode=68.197.13.94:8886
addnode=109.30.168.16:8886
http://www.multifaucet.tk/index.php?blockexplorer=BSD
Miscellaneous
    Standalone CPU Miner:
        Source: https://github.com/ig0tik3d/darkcoin-cpuminer-1.2c
        Source: https://github.com/elmad/darkcoin-cpuminer-1.3-avx-aes  (Faster if you have the AES-NI instruction set)
        Windows: http://dash.org/downloads/xcoin-miner.zip
        Windows 1.2 avx-aes: http://dash.org/downloads/darkcoin-minerd-1.2c.zip
        Windows 1.3 avx-aes: http://download.darkcoin.fr/darkCoin-cpuminer-1.3-avx-aes-windows-binaries.zip
    Standalone GPU Miner:
        Source: https://github.com/prettyhatemachine/sph-sgminer
        Windows: https://mega.co.nz/#!2JYXHDpD!OOiFOdsh5rnvk1zhz5niXENNzbgnw1UXwmFcicBzevI
        phm’s bitcointalk thread: https://bitcointalk.org/index.php?topic=475795.0;all
     Info The Value for a Paperwallet:
Code: [Select]
name, networkVersion, privateKeyPrefix, WIF_Start, CWIF_Start, donate
 ("BitSend",  0x66, 0xcc, "7",    "X"    , "i7RDkQoKYNjGkVWe4zkZeKZN7PGZVjfzdX")
vindynegroup.com
