  • Total Topics: 16528
  • Online today: 3114
Guests: 3000
Total: 3002
Author Topic: McAfee VirusScan Enterprise 8.8 - Patch 7 (download)  (Read 100086 times)
Re: McAfee VirusScan Enterprise 8.8 - Patch 7 (download)
« Reply #10 on: 21. March 2016., 16:09:05 »
Ok, then you can Try disabling manually the On-Access Scanner on VSE's Console, for that you'll have to check the Access Protection Control.
The other way would be a full VSE Reinstall
Audiracecar90
« Reply #11 on: 22. March 2016., 12:42:53 »
ok thanks for your info :)
« Reply #12 on: 24. March 2016., 10:24:40 »
Hi!
Password please!  ;)
« Reply #13 on: 24. March 2016., 10:32:30 »
Have you got true from the problem? If not note that you need to have patch 1 previous installed on an 32bit system and Patch 2 64bit system. Other wise you are not able to install this patch!
See the release notes of the patch.
« Reply #14 on: 25. March 2016., 00:19:00 »
Hi!
Password please!  ;)
On its way :p
zocker
« Reply #15 on: 29. March 2016., 22:28:04 »
Very nice!
May I get the password please? Thanks!
zocker
« Reply #16 on: 31. March 2016., 21:14:43 »
Patch requires at least patch 2 to be installed. It won't install over VSE 8.8 RTM or VSE 8.8 Patch 1
Just one important addition: you need at least McAfee Agent 4.8.0.1500 or 5.0.2.188/5.0.2.333. See here:
https://kc.mcafee.com/corporate/index?page=content&id=KB51111#MA
I had the an older Version and the Patch didn't install. If you need McAfee Agent, you an take a look at the full version of McAfee VSE 8.8 with Patch 6 package. The FramePkg_UPD.exe contains McAfee Agent.
« Reply #17 on: 31. March 2016., 22:01:27 »
For these cases, usually the patch package also comes with the McAfee Agent Installer for the minimum requeried version
zocker
« Reply #18 on: 31. March 2016., 22:27:05 »
At least this time McAfee Agent isn't included in the patch. With former patches (like Patch 6) McAfee Agent hasn't been upgraded to latest version as I found out on my machines.
bugmenot
« Reply #19 on: 04. April 2016., 13:33:01 »
Could you send me the password ?
Thanks
