  • Total Topics: 16528
  • Online today: 3114
Guests: 3001
Total: 3003
Author Topic: PAGE WITH A BUG ?  (Read 42099 times)
A41202813GMAIL
  • XPOCALYPSE FOREVER !
PAGE WITH A BUG ?
« Reply #10 on: 19. April 2016., 04:38:14 »
OPERA15+ Is A CHROME Clone, Not An FF Clone.
If You Have Some Detailed Instructions, I Will Execute Them As Soon As Possible.
I Have Problems With RACER, As Well.
In Both Sites, Something Related With Waiting For RESOURCES.INFOLINKS.COM.
Thank You.
PAGE WITH A BUG ?
Re: PAGE WITH A BUG ?
« Reply #11 on: 19. April 2016., 07:24:02 »
If only I could read all that is discussed here... I might have been able to help  >:D
A41202813GMAIL
PAGE WITH A BUG ?
« Reply #12 on: 19. April 2016., 07:50:50 »
You Are Already Doing Such An Outstanding Job Constantly Lowering My Karma.
Please, Do Not Stop.
PBMKMLENAKMKOMPEOGDPANGLECGNDFDC - For The Fourth Time.
« Reply #13 on: 20. April 2016., 01:50:59 »
Thank You.
There you have it, it's waiting for some JS and/or img from the ads.
So first option would be to activate an ad-blocker and see if it still doesn't load
I'll study second option that would be looking for partial rendering
« Reply #14 on: 20. April 2016., 02:18:02 »
Well, I haven't been able to find a setting that enables partial rendering, so for the time being you can try to start an adblocker against infolinks.com and see if it helps (Samker will want my head on a plate for this, but well..)
A41202813GMAIL
PAGE WITH A BUG ?
« Reply #15 on: 20. April 2016., 17:31:10 »
On My Account You Can Keep Your Head.
If I Can Not Solve The Problem Otherwise, I Will Continue To Use CHROME To Reply To Your Site - And That Is A Promise.
You Have Enough User Info To Check If I Am Lying Or Not, Right ?
Thank You So Much.
« Reply #16 on: 26. April 2016., 19:59:26 »
FYI, Infolinks is an Advertising network which services We use to cover running costs (hosting server, etc.).
I asume that J. have right about this... Probably you have problems because of some Ad which need some time to show on your desktop... below you have an example how it looks (when mouse cursor is on it):
Generally, these ads are not so intrusive and We have max. two per page.
However, if you still have the same problem with this service, We'll try to fix issue & in case that We don't succes, these ads will be disabled.
Visitors experince and satisfaction are on higher place than $$$. :police:
Kindly check again and inform us do you still have the same problem with page loading ??
Thanks,
P.S.
... you can try to start an adblocker against infolinks.com and see if it helps (Samker will want my head on a plate for this, but well..)
 ;D
A41202813GMAIL
PAGE WITH A BUG ?
« Reply #17 on: 26. April 2016., 23:35:03 »
I Can Not Reply To Any Thread With OPERA15+.
As I Said, I Will Continue To Use CHROME To Reply.
I Do Not Believe This Is An OPERA15+ Problem, Because The Penultimate Version Was Working Well And Now The Last 2 Versions Do Not Work, At All.
Did INFOLINKS Change Something 8 Or 9 Days Ago ? - I Check SCFORUM And RACER Regularly.
Since This Is A Problem That Affects Other Sites ( RACER ) And OPERA15+ Issues A Newer Version Several Times Each Month, I Hope INFOLINKS Corrects Whatever They Have Changed, Because If It Affects Me I Believe It Will Affect A Lot Of Other People, Too.
Lets Wait For The Next Couple Of Weeks.
Thank You.
« Reply #18 on: 29. April 2016., 20:42:49 »
dID nOT rEAD.  :thumbsdown:
A41202813GMAIL
PAGE WITH A BUG ?
« Reply #19 on: 30. April 2016., 23:10:26 »
26+ To Go.
PBMKMLENAKMKOMPEOGDPANGLECGNDFDC - For The Fifth Time.
NO TO RACISM.
PAGE WITH A BUG ?
