  • Total Topics: 16528
  • Online today: 3114
Guests: 2992
Total: 2994
Author Topic: PAGE WITH A BUG ?  (Read 42096 times)
Re: PAGE WITH A BUG ?
« Reply #20 on: 01. May 2016., 15:17:46 »
I still don't get what's going on between you two...
« Reply #21 on: 02. May 2016., 09:38:03 »
I Can Not Reply To Any Thread With OPERA15+.
As I Said, I Will Continue To Use CHROME To Reply.
I Do Not Believe This Is An OPERA15+ Problem, Because The Penultimate Version Was Working Well And Now The Last 2 Versions Do Not Work, At All.
Did INFOLINKS Change Something 8 Or 9 Days Ago ? - I Check SCFORUM And RACER Regularly.
Since This Is A Problem That Affects Other Sites ( RACER ) And OPERA15+ Issues A Newer Version Several Times Each Month, I Hope INFOLINKS Corrects Whatever They Have Changed, Because If It Affects Me I Believe It Will Affect A Lot Of Other People, Too.
Lets Wait For The Next Couple Of Weeks.
FYI, Infolink's code was implemented on SCF before few Years... after that, We didn't changed anything on our side and I don't have information that they changed something. :-\
As you proposed, let's wait for some time. ;)
P.S.
By the way, don't know is't related, but We have report from one member that He have some small issues with Edge browser. Can someone check/confirm ??
A41202813GMAIL
  • XPOCALYPSE FOREVER !
PAGE WITH A BUG ?
« Reply #22 on: 02. May 2016., 15:01:51 »
FF And, Especially, CHROME Have A Lot Of Clones To Choose From.
No Worries.
Thank You.
« Reply #23 on: 02. May 2016., 18:39:24 »
@S. Gimme an specific test case and I can try.
A41202813GMAIL
PAGE WITH A BUG ?
« Reply #24 on: 03. May 2016., 05:41:50 »
I ( Manually ) Solved The Problem With RACER.
( X = Not Working URL )
I Do A Search With ( X ) And GOOGLE Gives Me Several Different URLS Pointing To The Same Article.
I Experimented With Several Problematic URLS And I Always Found A New One That Works - Meaning Not All URLS Include The Same INFOLINKS Material.
1 Problem Solved - No Luck With SCFORUM Yet, Though.
Cheers.
PAGE WITH A BUG ?
A41202813GMAIL
PAGE WITH A BUG ?
« Reply #25 on: 03. May 2016., 07:50:54 »
I Have 2 Problems With SCFORUM And OPERA15+:
A - I Can Not Read Any Thread Normally,
B - Because Of ( A ), I Can Not Reply, Either.
Well, At Least, Problem ( A ) Is Somewhat Resolved.
There Is A Site Called newscentral.exsees.com That Replicates Every Single SCFORUM Post.
I Found Them When Doing A GOOGLE Search With An Extension ID Code I Keep Using Here.
EDIT:
This Very Post Was Replicated There In A Matter Of Minutes.
Cheers.
« Reply #26 on: 08. May 2016., 11:32:58 »
P.S.
Great, please try to insert some image and/or smileys using Microsoft's Edge browser.
Hmmm... I hope that, after J.'s tests with Edge, We'll have more clues.
« Reply #27 on: 08. May 2016., 15:40:04 »
Well, with Edge it took quite a few mins to load the page.. I don't know if my notebook is becoming crazy (very probably), or it was a JS-related issue.
As for the emoticon, here comes the afro:
Nope, I click it and nothing happens..
A41202813GMAIL
PAGE WITH A BUG ?
« Reply #28 on: 08. May 2016., 19:16:07 »
Of Course, This Is Not My Area By A Country Mile, But With The Evidence Presented To Me, I Continue To Believe INFOLINKS Changed Something On Their Side - Something That OPERA15+ Can Not **Swallow** - Yet.
Thank You.
« Reply #29 on: 09. May 2016., 00:03:09 »
Perhaps you can try disabling JS :p
