  • Total Topics: 17050
  • Online today: 10764
Guests: 10762
Total: 10764
Author Topic: Auto-cad files won't open  (Read 11775 times)
AkseliJaakkola
« on: 16. May 2016., 15:07:47 »
Restored data and auto-cad files won't open. Have the .bak files that auto-cad saves during work performed on .dwg files.
My understanding is rename the .bak to .dwg and the file will open, however it give an error the file cannot be opened.
Anyone seen this before and know how to open auto-cad .bak files?
Re: Auto-cad files won't open
« Reply #1 on: 21. May 2016., 09:44:06 »
... however it give an error the file cannot be opened.
Can you provide us more information about error ? Number, etc. ?
By the way, here you have some useful info: https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Understanding-AutoCAD-backup-and-autosave-files.html
ErnoDudas
« Reply #2 on: 23. May 2016., 16:36:29 »
Hi
I assume you have seen this:
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/AutoCAD-File-Corruption.html
http://knowledgemanagement.ittoolbox.com/groups/technical-functional/km-general-l/cant-open-dwg-file-5633709
Renaming is the standard way of doing a 'restore', but check out the deletion of dwl lock files. If you go through some of the AutoCAD forums you also find recommendations to use the INSERT function into blank DWG as suggested in the link.
ErnoDudas
« Reply #3 on: 23. May 2016., 16:40:18 »
Also you can check and restore your data successfully using DWG Recovery Toolbox.
http://www.oemailrecovery.com/dwg_recovery.html
I hope my answer was useful for you.) And don't forget first of all to make a backup!
AkseliJaakkola
« Reply #4 on: 27. May 2016., 14:52:38 »
Thank you guys for your feedback and help. Sorry, that long time did not respond. This is because the issue was solved and I forgot to tell.) Thank you!
