  • Total Topics: 16999
  • Online today: 23577
Guests: 20307
Total: 20307
Author Topic: Files on external drive changed to shortcuts.doc resolved  (Read 16731 times)
unite4real
Hello,
Try this 1.
Check whether the files are not in hidden mode. Follow the following steps.
Step 1:
Click on the below link and download the file "AutorunExterminator"
http://en.kioskea.net/download/download-11613-autorun-exterminator
Extract it --> Double-click on "AutorunExterminator" --> Plug your External
hard drive now.
This will remove the autorun.inf files from your External hard drive and also from
the drives.
Step 2:
Click on "Start" -->Run --> type cmd and click on OK.
Here I assume your External hard drive as G:
Enter this command.
attrib -h -r -s /s /d g:\*.*
You can copy the above command --> Right-click in the Command Prompt and
paste it.
Note : Replace the letter g with your External hard drive letter.
Now check for your files in External Drive.
Step 3:
After that, download the Malwarebytes' Anti-Malware from the below link
http://en.kioskea.net/download/download-105-malwarebytes-anti-malware
Update it --> Perform "Full Scan"
Note : Default selected option is "Quick Scan".
Good Luck.
Re: Files on external drive changed to shortcuts.doc resolved
« Reply #1 on: 17. August 2016., 17:52:44 »
Nice tip, thanks! :thumbsup:
