  • Total Topics: 16978
  • Online today: 137655
Guests: 134777
Total: 134779
Author Topic: W32.Stration.IZ@mmRisk  (Read 7371 times)
0 Members and 14 Guests are viewing this topic.
« on: 12. May 2007., 18:02:40 »
W32.Stration.IZ@mmRisk Level 2: LowDiscovered: May 10, 2007
Updated: May 10, 2007 5:14:00 PM
Type: Worm
Infection Length: 79,092 bytes
Systems Affected: Windows 98, Windows 95, Windows XP, Windows Me, Windows NT, Windows Server 2003, Windows 2000
SUMMARYW32.Stration.IZ@mm is a worm that spreads by emailing itself to other computers. It also drops and downloads other variants in the W32.Stration@mm family of worms.
ProtectionVirus Definitions (LiveUpdate™ Daily) May 11, 2007
Virus Definitions (LiveUpdate™ Weekly) May 16, 2007
Virus Definitions (Intelligent Updater) May 11, 2007
Virus Definitions (LiveUpdate™ Plus) May 11, 2007
Threat AssessmentWildWild Level: Low
Number of Infections: 0 - 49
Number of Sites: 0 - 2
Geographical Distribution: Low
Threat Containment: Easy
Removal: Easy
DamageDamage Level: Medium
Payload: Drops and downloads other variants in the W32.Stration@mm family of worms.
Large Scale E-mailing: Sends a copy of itself to email addresses gathered.
DistributionDistribution Level: Medium
TECHNICAL DETAILSOnce executed is executed, the worm drops the following files:
%System%\msstersv.dll - detected as W32.Stration@mm
%System%\secumsje.exe - detected as W32.Stration.IZ@mm
%System%\secumsje.dat - clean dat file
%System%\trafracp.dll - detected as W32.Stration@mm
%System%\shfoxpob.exe - detected as W32.Stration.IZ@mm
%System%\shfoxpob.dat - clean dat file
It may create the following mutexes to ensure that only one copy of the worm is running:
89cd0a69-e389-42d1-a968-5ba7319db25b
5a6406d5-43cb-4d29-8377-df016be7c055
It may create some of the following system events:
MAAllowEvent
MAAllowEvent2
NISMailAllowEvent
NISAllowEvent2
NISAllowEvent
OPAllowEvent
OPAllowEvent2
SGAllowEvent2
SGAllowEvent
ZAAllowEvent2
ZAAllowEvent
The worm creates the following the following registry entry:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\"AppInit_DLLs" = "trafracp.dll"
The worm also creates the following registry subkeys:
HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\Notify\shfoxpob
HKLM\SOFTWARE\Microsoft\shfoxpob
It then check the following registry subkeys and entries related to firewall products:
HKEY_LOCAL_MACHINE\SOFTWARE\Zone Labs\ZoneAlaram
HKEY_LOCAL_MACHINE\SOFTWARE\Sygate Technologies, Inc.\Sygate Personal Firewall
HKEY_LOCAL_MACHINE\SOFTWARE\Symantec\Internet Security
HKEY_LOCAL_MACHINE\SOFTWARE\Symantec\InstalledApps
HKEY_LOCAL_MACHINE\SOFTWARE\Agnitum\Outpost Firewall
HKEY_LOCAL_MACHINE\SOFTWARE\McAfee.com\Personal Firewall
HKEY_LOCAL_MACHINE\SOFTWARE\Kerio\WinRoute
It attempts to disable some of those firewall products.
The worm attempts to contact the following remote site to download additional malicious files using TCP port 80:
[http://]ertikadeswiokinganfuja.com/chr/1021/e/[RANDOM F[REMOVED]
[http://]81.95.149.235/scorp/file[REMOVED] - detected as Downloader
[http://]baserionkerjans.com/34.[REMOVED]
It sends windows messages to the following programs to bypass security restrictions and firewall:
ccapp.exe
firefox.exe
iexplore.exe
mpftray.exe
opera.exe
outpost.exe
services.exe
smc.exe
svchost.exe
zapro.exe
zlclient.exe
It resolves the following domain name to check for availability of SMTP connection on TCP port 25:
yahoo.com
The worm gathers email addresses from the compromised computer and sends a copy of itself to these email addresses. It may send itself as a .zip file with a .exe inside.RecommendationsSymantec Security Response encourages all users and administrators to adhere to the following basic security "best practices":
Turn off and remove unneeded services. By default, many operating systems install auxiliary services that are not critical, such as an FTP server, telnet, and a Web server. These services are avenues of attack. If they are removed, blended threats have less avenues of attack and you have fewer services to maintain through patch updates.
If a blended threat exploits one or more network services, disable, or block access to, those services until a patch is applied.
Always keep your patch levels up-to-date, especially on computers that host public services and are accessible through the firewall, such as HTTP, FTP, mail, and DNS services (for example, all Windows-based computers should have the current Service Pack installed.). Additionally, please apply any security updates that are mentioned in this writeup, in trusted Security Bulletins, or on vendor Web sites.
Enforce a password policy. Complex passwords make it difficult to crack password files on compromised computers. This helps to prevent or limit damage when a computer is compromised.
Configure your email server to block or remove email that contains file attachments that are commonly used to spread viruses, such as .vbs, .bat, .exe, .pif and .scr files.
Isolate infected computers quickly to prevent further compromising your organization. Perform a forensic analysis and restore the computers using trusted media.
Train employees not to open attachments unless they are expecting them. Also, do not execute software that is downloaded from the Internet unless it has been scanned for viruses. Simply visiting a compromised Web site can cause infection if certain browser vulnerabilities are not patched.
REMOVALThe following instructions pertain to all current and recent Symantec antivirus products, including the Symantec AntiVirus and Norton AntiVirus product lines.
Disable System Restore (Windows Me/XP).
Update the virus definitions.
Run a full system scan.
Delete any values added to the registry.
For specific details on each of these steps, read the following instructions.
1. To disable System Restore (Windows Me/XP)
If you are running Windows Me or Windows XP, we recommend that you temporarily turn off System Restore. Windows Me/XP uses this feature, which is enabled by default, to restore the files on your computer in case they become damaged. If a virus, worm, or Trojan infects a computer, System Restore may back up the virus, worm, or Trojan on the computer.
Windows prevents outside programs, including antivirus programs, from modifying System Restore. Therefore, antivirus programs or tools cannot remove threats in the System Restore folder. As a result, System Restore has the potential of restoring an infected file on your computer, even after you have cleaned the infected files from all the other locations.
Also, a virus scan may detect a threat in the System Restore folder even though you have removed the threat.
For instructions on how to turn off System Restore, read your Windows documentation, or one of the following articles:
How to disable or enable Windows Me System Restore
How to turn off or turn on Windows XP System Restore
Note: When you are completely finished with the removal procedure and are satisfied that the threat has been removed, reenable System Restore by following the instructions in the aforementioned documents.
For additional information, and an alternative to disabling Windows Me System Restore, see the Microsoft Knowledge Base article: Antivirus Tools Cannot Clean Infected Files in the _Restore Folder (Article ID: Q263455).
2. To update the virus definitions
Symantec Security Response fully tests all the virus definitions for quality assurance before they are posted to our servers. There are two ways to obtain the most recent virus definitions:
Running LiveUpdate, which is the easiest way to obtain virus definitions.
If you use Norton AntiVirus 2006, Symantec AntiVirus Corporate Edition 10.0, or newer products, LiveUpdate definitions are updated daily. These products include newer technology.
If you use Norton AntiVirus 2005, Symantec AntiVirus Corporate Edition 9.0, or earlier products, LiveUpdate definitions are updated weekly. The exception is major outbreaks, when definitions are updated more often.
Downloading the definitions using the Intelligent Updater: The Intelligent Updater virus definitions are posted daily. You should download the definitions from the Symantec Security Response Web site and manually install them.
The latest Intelligent Updater virus definitions can be obtained here: Intelligent Updater virus definitions. For detailed instructions read the document: How to update virus definition files using the Intelligent Updater.
3. To run a full system scan
Start your Symantec antivirus program and make sure that it is configured to scan all the files.
For Norton AntiVirus consumer products: Read the document: How to configure Norton AntiVirus to scan all files.
For Symantec AntiVirus Enterprise products: Read the document: How to verify that a Symantec Corporate antivirus product is set to scan all files.
If any files are detected, follow the instructions displayed by your antivirus program.
Important: If you are unable to start your Symantec antivirus product or the product reports that it cannot delete a detected file, you may need to stop the risk from running in order to remove it. To do this, run the scan in Safe mode. For instructions, read the document, How to start the computer in Safe Mode. Once you have restarted in Safe mode, run the scan again.
After the files are deleted, restart the computer in Normal mode and proceed with the next section.
Warning messages may be displayed when the computer is restarted, since the threat may not be fully removed at this point. You can ignore these messages and click OK. These messages will not appear when the computer is restarted after the removal instructions have been fully completed. The messages displayed may be similar to the following:
Title: [FILE PATH]
Message body: Windows cannot find [FILE NAME]. Make sure you typed the name correctly, and then try again. To search for a file, click the Start button, and then click Search.
4. To delete the value from the registry
Important: Symantec strongly recommends that you back up the registry before making any changes to it. Incorrect changes to the registry can result in permanent data loss or corrupted files. Modify the specified subkeys only. For instructions refer to the document: How to make a backup of the Windows registry.
Click Start > Run.
Type regedit
Click OK.
Note: If the registry editor fails to open the threat may have modified the registry to prevent access to the registry editor. Security Response has developed a tool to resolve this problem. Download and run this tool, and then continue with the removal.
Navigate to and delete the following entries:
Navigate to and delete the following subkeys:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\shfoxpob
Exit the Registry Editor.
