  • Total Topics: 16529
  • Online today: 3056
Guests: 2973
Total: 2976
Author Topic: How to Print out Text Messages from Android?  (Read 6428 times)
lucyll
« on: 26. September 2016., 03:11:14 »
Are you fond of reading old text messages, which may be sent by your girlfriend/boyfriend or close friends? In fact, reading SMS messages is a good way to help us recall those beautiful memories. While, if you get your Android cell phone stolen, broken, smashed or formatted, you may lose your text messages accidentally. Then I suggest you to print them out for better reading and backing up, or other uses. To print text messages android, we can use iPubsoft Android File Manager to transfer text messages from android phone to computer first, then select and check those text messages you want to print out and export them to computer.
How to print text messages:
Step 1. Run this Program and Connect Your Android Device to PC
Connect your android phone to computer via the usb cable and start the app, the app would detect your phone data automatically.
If this is the first time you connect your android phone to computer, you shoule enable the USB debugging. You can follow the guide to open the USB bugging: Enter "Settings" < Click "Applications" < Click "Development" < Check "USB debugging".
Step 2. Export Text Message Conversations to PC and Print them Out
All the files in your cell phone will show in categories on the left menu. Just click the "SMS" icon and you will enter the Contacts window. All the text messages in your phone will show in list here, selece and check those you want to prin out and click the button of "Export".
Open the transferred text messages and print them out as you like.
(--- Links removed by Admin ---)
cfsdf
Re: How to Print out Text Messages from Android?
« Reply #1 on: 12. October 2016., 06:54:10 »
Thanks for sharing this, to print text messages android, you can also use Coolmuster Android Assistant to help, transfer sms from phone to computer in few simple steps, then you can open the transferred file and print them out as you like.
justchengke
« Reply #2 on: 15. February 2017., 08:47:15 »
To print out Android messages, you can ask help from Vibosoft Android Message Manager program. With it, you can easily print text messages from Android phone into word document or html. file without any restrictions.
(--- SPAM link removed by Admin ---)
Emily Wong
« Reply #3 on: 23. February 2017., 01:50:33 »
As for me, the most convenient and time-consuming way to print text messages from Android is using Jihosft Phone Transfer, which is powerful enough to export sms, contacts, photos, videos and more files from android device to computer for printing or any other uses.
mahehs150
« Reply #4 on: 27. April 2017., 07:44:17 »
5 Simple steps to  print
Step 1. Launch the program and connect your device to the computer
Step 2. Enable USB debugging
Step 3. Analyze and scan your Android phone
Step 4. Preview and save text messages on Android for print
Step 5. Print Android text messages
technicalguy
« Reply #5 on: 30. June 2019., 10:03:22 »
its as simple as sending a text message
1. put the usb connection between mobile and pc
2.accept the connection for file transfer
3.open the text msg
4.in option you will see print
5 click the print and your material will be printed  :D
