  • Total Topics: 10072
  • Online Today: 1177
Author Topic: is mcafee virus scan 8.8 patch 7 supported for windows 10?  (Read 2739 times)
dsrkrishna4u
is mcafee virus scan 8.8 patch 7 supported for windows 10? which patch will support in windows 10
Re: is mcafee virus scan 8.8 patch 7 supported for windows 10?
« Reply #1 on: 18. October 2016., 14:11:17 »
Patch 8, as stated in Release notes.
Pitti1960
« Reply #2 on: 18. October 2016., 15:26:33 »
The mcafee virusscan 8.8 Patch 7 works in Windows 10 Version 1511 not in Version 1607.
« Reply #3 on: 20. October 2016., 08:02:00 »
After the latest update of Windows 10 with build 1607 you need to use Patch 8 to make VirusScan 8.8 to work and bee supported!
So for today you need Patch 8.
mmgpotax
« Reply #4 on: 08. January 2017., 17:36:39 »
It supports perfectly this patch the windows 10 version, correct operation and also very stable.
It does not update automatically if you do not indicate it in the configuration.
Forgive for my English.
Christianplata
« Reply #5 on: 23. April 2017., 16:24:25 »
Patch 8 works fine on the 1607, but it has a problem in the installation, and it's that it can take many minutes or even hours to finish the installation, but then it works fine. Now for version 1703 if only the patch 9 necessarily works.
biophyllum
« Reply #6 on: 23. May 2017., 20:00:53 »
Windows 10 Update 1703 insists uninstalling of McAfee Virus Scan 8.8 Patch 8 to continue with the update. Hence, run windows 10 update 1703 only after applying patch 9.  :bih:
young12
« Reply #7 on: 11. August 2017., 17:13:47 »
How do you go about getting patch 9?
xchard
« Reply #8 on: 12. September 2017., 15:12:11 »
mukesh
« Reply #9 on: 13. November 2017., 20:52:43 »
Nice explanation..
