  • Total Topics: 10073
  • Online Today: 1141
Author Topic: VoodooShield Pro (10 x 2 years Licenses) Giveaway  (Read 758 times)
Jarom
« on: 12. January 2017., 03:43:31 »
The competition ends: February 12th, 2017
THE CONCEPT
IF YOUR COMPUTER IS RUNNING A WEB APP, IT NEEDS TO BE LOCKED. PERIOD.
NOT A FILTER. NOT A SANDBOX. NOT VIRTUALIZATION. AN ABSOLUTE LOCK.
Simple Approach
Traditional blacklist antivirus software can no longer keep up with the 200,000+ new viruses and malware created daily, so VoodooShield locks your computer and blocks all new, non-whitelisted executable code (including viruses and malware), while your computer is running a web app (browser, email, etc.). Traditional antivirus is great, but your computer should be locked when it is at risk.
The VoodooShield Difference
VoodooShield uses a proprietary proactive whitelist snapshot approach to virus and malware protection. VoodooShield is a patented toggling Desktop Shield Gadget / Computer Lock that automatically toggles to ON and locks your computer when you start a web app. There is never a good reason to let new, non-whitelisted executable code run while a web app is running.
For Home and Business
Since most viruses and malware attack through web browsers and email attachments, VoodooShield simply locks your computer when you are browsing the web or checking email. It also protects the user space when not at risk. When used properly, VoodooShield will effectively block all browser and email based viruses and malware. VoodooShield does not remove existing viruses.
VoodooShield’s three layers of protection include an application whitelisting lock, a machine learning / Ai
decision engine and a multi-engine blacklist scan. The application whitelisting lock automatically toggles to
ON when the computer is at risk to lock your computer and keep you safe while browsing the web or checking email.
While the machine learning / Ai and multi-engine blacklist scanners automatically scan new and unknown executable files
to ensure that malware is not accidentally allowed by the end user.
How VoodooShield Works
VOODOOSHIELD WILL TOGGLE BETWEEN ON AND OFF, DEPENDING ON WHETHER YOU ARE AT RISK OR NOT
OFF Mode (Unlocked): Your computer is unlocked, and VoodooShield is learning which programs to allow so it will not block them once VoodooShield locks your computer. You can also change to this mode if you need to install or allow additional software. Your computer is NOT protected in this mode.
ON Mode (Locked): Your computer is locked and you are protected. When VoodooShield automatically toggles to ON Mode, it takes a snapshot of the currently running software, and automatically allows everything in this snapshot. VoodooShield also automatically allows currently installed software and specific critical Windows system files. Any software that was not allowed when VoodooShield was OFF is blocked.
There is only one thing to keep in mind when using VoodooShield...
If VoodooShield blocks something that you would like to run, then allow it after it is automatically scanned.
Otherwise, if VoodooShield blocks something out of the blue, then just ignore it and assume it was a virus or malware.
Compatible with Windows Vista, 7, 8, & 10
http://programyzafree.com.pl/index.php?topic=2219.0
Re: VoodooShield Pro (10 x 2 years Licenses) Giveaway
« Reply #1 on: 13. January 2017., 19:44:07 »
Great, thanks for info...  :thumbsup:
Keep them coming!
cya around,
Jarom
« Reply #2 on: 19. January 2017., 15:24:15 »
Attention! We had our database crashed recently. You might need to check if your previously created account exists. If not, please create your account again. We are sorry for inconvenience.
http://programyzafree.com.pl/index.php?topic=2219.msg7601
