  • Total Topics: 16999
  • Online today: 23577
Guests: 20830
Total: 20830
Author Topic: Top 5 Free Single File Online Virus Scan Services  (Read 42697 times)
« on: 08. December 2007., 10:26:22 »
I scoured the Web to find the best single file antivirus scanners and I have found 5 services worth checking out. In choosing the top 5, I should have a basis so I created one. I based my criteria on convenience, file size capability, browser compatibility, update frequency and service load. Without further ado, here they are!
The top 5 free single file online virus scan services:
1. VirusTotal -> http://www.virustotal.com/
2. Virus.org Rogue File Scanning Service -> http://scanner.virus.org/
3. Jotti’s Malware Scan 2.99 -> http://virusscan.jotti.org/
4. Dr. Web AntiVirus -> http://online.drweb.com/
5. Kaspersky File Scanner -> http://www.kaspersky.com/scanforvirus
6. avast! Online scanner -> http://onlinescan.avast.com
7. VirusChief -> http://www.viruschief.com/index.html
8. VirSCAN.org -> http://virscan.org/
9. NoVirusThanks -> http://vscan.novirusthanks.org/
Let me give you a brief explanation of the criteria:
Convenience
Upon arriving to the Web site, the user interface should be intuitive. Moreover, results should be given on-demand. Transmission of results through other means such as e-mail shouldn’t be a requirement.
File Size Capability
As a rule of thumb, the bigger, the better. However, it is understandable that some single file scanning services currently do not support files that are more than 15 MB.
Browser Compatibility
They should support major modern browsers such as Internet Explorer 6, Internet Explorer 7, Firefox 2, Opera 9, and Safari for Windows.
Update Frequency
Definition files should be updated regularly, preferrably hourly. Scan engines should be updated regularly.
Service Load
Delays on a per-user basis should be minimized. The time on queue is important.
Single file online antivirus scanners are especially helpful in software development and file sharing. To ensure a file’s cleanliness and integrity, it should be tested against different antivirus scanners. It will be inconvenient and impractical to install several antivirus software in your computer to test a file, so what better way to do it than to visit these free single file online virus scan services. However, there are limitations to this approach. Since the services are free, they’re always prone to misuse. That’s why most of these services impose a limit on the size of a file that can be scanned. Others send results through e-mail to gain further control. Whatever the limitations are, we should be thankful that they exist.
VirusTotal
VirusTotal deserves the top spot at the moment. Aside from its intuitive UI, it supports 10 MB file sizes as well. Furthermore, it scans from 30 AV programs.
  • I tested the site in: IE7 (minor display problems on results page), IE6, Firefox 2, Opera 9.21, Safari 3 for Windows
    Uses the Flash player plugin for its stats.
    10 MB limit
    Scans from 30 antivirus programs including McAfee, Symantec, and Trend Micro
    Average service load < 50%
    Results are given right away. An option to send a file to be scanned through e-mail is also available.
The second spot goes to Virus.org Rogue File Scanning Service. UI is similar to VirusTotal. Perhaps the only significant difference it has with VirusTotal is the service load. When I went there, the load was quite high. It would have been at the top spot (since it supports files that are more than 10 MB) if its service load was less than 50% on average.
  • I tested the site in: IE6, IE7, Firefox 2, Opera 9.21, Safari 3 for Windows
    undetermind file size limit, though it accommodated a 39.8 MB file.
    Scans from 18 antivirus programs including McAfee and Trend Micro
    Service load ~70%
The third spot goes to Jotti’s Malware Scan. Now you may have noticed that the top 3 uses several antivirus programs. The remaining two will only be using one scanner.
    10 MB limit
    Scans from 18 antivirus programs including AVG, F-secure, Kaspersky, NOD32, and Panda AV
    Service load is often ~95%
Dr. Web Anti-Virus
The file scan interface was kinda difficult to find in the Web site. However, the results page was presented very well.
  • I tested the site in: IE6, IE7, Firefox 2, Opera 9.21 (blocked pop-up results page; unexpected window/tab behavior), Safari 3 for Windows
    undetermined file size limit, though it accommodated a 15.7 MB file
    Scans from the Dr. Web AV engine
The Kaspersky File Scanner doesn’t really stand a chance against the top 3 services. Its 1 MB limit isn’t useful enough. However, Kaspersky is one of the best AV programs out there, in my opinion.
  • I tested the site in IE6, IE7, Firefox 2, Opera 9.21, Safari 3 for Windows is unsupported
    1 MB limit
    Scans from the Kaspersky AV engine
(Copyright by Project Afterlight)
zilzzaal
Re: Top 5 Free Single File Online Virus Scan Services
« Reply #1 on: 21. March 2008., 21:05:58 »
thanxxxxxxxx alot
cozy_dave
« Reply #2 on: 14. March 2009., 02:33:52 »
good info... thanks
dave
« Reply #3 on: 09. October 2009., 10:11:23 »
tnx!!
tikuna
« Reply #4 on: 18. October 2009., 01:39:06 »
good info... thanks
stations
« Reply #5 on: 10. November 2009., 08:35:18 »
good... thx..
fotis100
« Reply #6 on: 12. March 2010., 09:30:35 »
very good info. thanks...
janissary
« Reply #7 on: 12. May 2010., 13:23:03 »
Thank you. I use VirusTotal uploader.
http://www.virustotal.com/metodos.html
grr
« Reply #8 on: 14. September 2010., 04:21:41 »
Hi Samker,
Thanks for the compilation and description of their services.
From my experience and use, I would point some others as well, which are worthe adding to ur post. Please consider them if you feel appropriate:
VirusChief
VirusChief is a service that analyzes suspicious files and facilitates the quick detection of viruses, worms, trojans, and all kinds of malware detected by antivirus engines.
Specs:
- Free, independent service
- Use of multiple antivirus engines
- Real-time automatic updates of virus signatures
- Detailed results from each antivirus engine
- Link output
- BB-Code output
- File deletion after the scan-report was generated
http://virscan.org/
VirSCAN.org is a FREE on-line scan service, which checks uploaded files for malware, using antivirus engines, indicated in the VirSCAN list. On uploading files you want to be checked, you can see the result of scanning and how dangerous and harmful/harmless for your computer those files are.
novirusthansk Multi-Engine Antivirus Scanner
http://scanner2.novirusthanks.org/
Free service that allows users to upload and scan a file with 24 Antivirus Engines. Users can also scan a website url or a remote file with the option Scan Web Address.
Thanks,
Grr
« Reply #9 on: 15. September 2010., 06:06:38 »
Added, Tnx grr.  :up:
P.S.
Don't know how, but I miss this post Yesterday...  :)
